Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Electronic Ignition (Throttle)
Old May 9, 2009 | 08:23 PM
BinIdaho's Avatar
BinIdaho
Angry Electronic Ignition (Throttle)
I am not a fan of this setup Went to the gas station and am in turn lane...trike dies. Do you think I could get it started again? NO! Turned switch off, clutch in and nothing. Rocked it back and forth..nothing. Cars behind me patiently waiting...had to go around. Finally, put in neutral, turned key on and the damn thing started. Now, I am coming home from the dealer later in the day and stopped at a light. Let out the clutch and trike dies again...SOB Same secenio....cars behind me can't go anywhere. Ten toes (reverse) to get to side of road. Hit the starter button...nothing. Turned switch off and back on...nothing. Wiggle the 'smart alarm' fob. Put in neutral, hit the starter button and fired up. Is this a common occurence, or am I letting out the clutch and not enough throttle? Do I need to study the owner's manual?
With the throttle setup...does the trike have to be in neutral?
Old May 9, 2009 | 09:06 PM
TheJimer's Avatar
TheJimer
Barbra,
I don’t think that the throttle has anything to do with your problem!
It could be as simple as the bike security system not detecting the security FOB because of a weak battery or poor connection.
Jim
Old May 9, 2009 | 09:44 PM
BinIdaho's Avatar
BinIdaho
Originally Posted by TheJimer
Barbra,
Jim
Jim,
Should I plug in the battery tender? TG sat in garage for a week without starting. Is this something I need HD Service to look at? (The key fob was in my pocket.)
Old May 10, 2009 | 07:11 AM
Keystone's Avatar
Keystone
Not the bikes battery Barb, the security fob battery. But that is just a guess. By your explanation I too doubt that it's the throttle causing the problem.
Old May 10, 2009 | 07:31 AM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Heres my theory
Is the bike still stock with no modifications? If so>>
The ECM for the fuel setup is set so lean that once your bike is hot its stumbling because of the added weight of the trike kit. Mine would be sluggish too until I got the PC V ( Not trying to promote the Power Commander stuff ) which gave me a fantastic throttle response even when the motor is hot.
For the bike not re-starting you stated that it was in gear both times when it stalled
The bike is setup to not start when the transmision is engaged. You have to remember to put it nuetral before trying to re-start
Just my 2cents. Hope this helps
Old May 10, 2009 | 08:11 AM
Mr. Wizard's Avatar
Mr. Wizard
FLTR>>>
I haven't heard that yet (not being able to start unless in neutral) but it wouldn't surprise me. Well, maybe it would just a little.
I know there is a switch that the clutch lever has to push inside the left switch housing. I think that started in 07 didn't it? But I didn't know it wouldn't start while in gear.
Oh.. Happy Mothers Day to all.
Old May 10, 2009 | 08:18 AM
triglide1's Avatar
triglide1
As long as you have the clutch pulled in, it should start in 1st gear. I have the smart siren on mine and you have to start it in gear or at least turn the ignition on while in gear and then put it in neutral or the siren will sound.
Old May 10, 2009 | 09:15 AM
Mr. Wizard's Avatar
Mr. Wizard
OK... everyone with a TG... go try to start it while in gear. Try 2nd gear too.
You too Barbara (while it is cold)... got a hunch and it has to do with Pop's previous posts.
Old May 10, 2009 | 11:37 AM
lzski326's Avatar
lzski326
Mine starts while in first gear, haven't tryed second gear yet. I dont use the parking brake so I always have it in first.
Old May 10, 2009 | 12:36 PM
FLTR2008TRIKE
I know that my trike will not start while the transmission is in gear. Not sure why others will or mine will not.
