Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Trailer wiring
Old Nov 14, 2010 | 08:46 AM
RoadHog659's Avatar
RoadHog659
Default Trailer wiring
Is this a typical wiring plug for a trailer? Just purchased an American Legend Sport (used) and it came with this 5-pin plug. Is there an adaptor that will get me hooked into my 09 Ultra wiring harness? All the adaptors I'm finding on-line have a different plug configuration.
Old Nov 14, 2010 | 09:50 AM
Ed Y's Avatar
Ed Y
No, that's not a typical plug for a "pull behind the motorcycle trailer" although it could be made to work.
1st thing you have to determine is whether the trailer is a 4 wire setup or a 5 wire setup. In other words, are each side turn signal and brake light run thru the same light housing or is there separate lights for each.
4 wire - ground, running light, right turn/brake, left turn/brake
5 wire - ground, running light, right turn, left turn, brake
Your bike is a 5 wire setup. In order to connect to a 4 wire trailer, you must have a converter.
Here's a good place to start with wiring options (scroll down to the wiring section). There are other outfits that sell 4 or 5 wire flat connectors too:
http://www.khromewerks.com/trailer_hitches.htm
Some food for thought. LED lights on the trailer really make for a good option. A lot less draw on the stock HD electrical system.
Old Nov 14, 2010 | 01:31 PM
Casper's Avatar
Casper
Looks like part of the above setup. I've had these in the past and don't care for them. The wires are pushed into the receptacle and then a set screw is tightened...they always came loose on me and cause problems.
I have found the best solution for me is;
1. get a connector the goes between the factory wiring for the rear of the bike, makes wiring a very simple job. Unplug the factory plug, snap the "jumper" plug between the factory plug and reconnect the factory plug. You will now have the wires for connecting the trailer coming off the factory plug. No cutting or splicing...easy removal for warranty work.
2. Go to Car Quest and buy a 5 wire rubber plug. Not a pretty as the chrome ones but it won't come loose and cause problems down the road.
works for me anyway.
I'll get a picture of that "jumper" plug and post it.
Old Nov 14, 2010 | 01:34 PM
Casper's Avatar
Casper
Here is a link to the "jumper" plug...course this is only one place, there are others.
http://www.shop.american-legend.com/...5&categoryId=8
Old Nov 14, 2010 | 01:48 PM
msocko3's Avatar
msocko3
Originally Posted by Casper
The Aluma MCT trailer I'm looking at comes with this style plug on it. Maybe I'll use a dab of lock tite blue when I assemble the female end on the trike.
Old Nov 14, 2010 | 03:30 PM
Morris9982's Avatar
Morris9982
Whatever type of harness you end up with, I'd suggest you look at an isolator type system.
These systems pull power directly from the bike and use the light connector to trigger a relay to light the trailer lights using the direct power line. That way you do not power the lights on the trailer from the power supplied to the bike's lights. This way is a lot safer for the bike's electrical system.
There is one shown in the Kromeworks link in a previous post.
mrjimbo
Sep 14, 2011 10:50 AM
AcesFull
Jul 24, 2011 05:16 PM
Jukebox
Aug 5, 2009 03:55 PM
Big Papa75
Jun 9, 2008 08:09 AM
CREEPSHOW
Mar 24, 2008 01:23 AM
