Plug for trailer lights
Old Feb 27, 2009 | 12:41 AM
Jukebox's Avatar
Jukebox
Default Plug for trailer lights
This is just a public service post. I just wired the plug in for my 4 pin plug on my trailer and it was easier and cheaper then I thought. Harleys are set up with the brake and blinkers seperate so if you buy just a simple trailer with a 4 pin plug and you don't want to splice or cut your wiring harness you can go to open road outditters and they have a whole set up for $144.00 but I only bought the H-D pass thru harness for $44.00 and a simple 4 pin plug from the auto parts store,plus I already H-D Run-Turn-Brake controller installed. I plugged the H-D pass thru harness into the Bike harness after the Run-Turn-Brake controller and I did not need the 5 to 4 wire converter at all. Just thought I would try to save your guys some cash that can used for chrome. Plus when I don't need the trailer plus I just remove the seat and unplug the wiring hrness and take out the Pass thru hraness,plug the wiring hraness and I am ready to go,no loose wires hanging around while I'm not using the trailer.Don't let someone try to sell something you don't need.
Old Aug 3, 2009 | 09:14 PM
Gymshorts8's Avatar
Gymshorts8
6th Gear
Have you had any problems with your electricial on your bike using this wiring setup
I have the same Run-Turn-Brake controller installed. on my 2007 ultra and I am getting ready to wire it up to pull a trailer
Thanx for any update
Old Aug 5, 2009 | 02:44 PM
Gymshorts8's Avatar
Gymshorts8
6th Gear
JohnnyP was wondering where you got the H-D pass thru harness is it after market
THanx Again for any help
Old Aug 5, 2009 | 03:55 PM
DPete's Avatar
DPete
There is a 4 pin blank connector with a rubber cap under my seat is that what you pluged into? I need brake , run and ground for a tour pak led rack I will be installing
mrjimbo
Sep 14, 2011 10:50 AM
AcesFull
Jul 24, 2011 05:16 PM
T K Glider
Apr 2, 2011 01:13 PM
RoadHog659
Nov 14, 2010 03:30 PM
Big Papa75
Jun 9, 2008 08:09 AM
