Trailer wiring harness
Old Sep 14, 2011 | 06:45 AM
mrjimbo's Avatar
mrjimbo
Default Trailer wiring harness
I am getting ready to install my wiring harness for the 4-pin connection to the trailer on my Ultra.
Can someone explain to me why I need to use this Isolation relay and the 5 to 4 wire adapter? Why can't I just splice the 4 pin harness in behind my load equalizer and be done with it? I just do not see where I am going to stuff all this wiring/relays under the seat/side panels. I already have Load equalizer, remote unit for ground effects lighting and the audible alarm horn.
My bikes lights are ALL led.......I just think I should be able to splice into the light wires and be done, where is my thinking off?
Thanks for the help,
Jimbo
Old Sep 14, 2011 | 07:24 AM
vzts4q's Avatar
vzts4q
Well a link to the product you are using would be helpful. But personally I avoid cutting and splicing at all costs. I used a product from Ride Time Technology for just that reason when I did some lighting changes. They make an adapter that breaks out the wiring needed for trailer wiring.
http://www.ridetimetechnology.com/qc...er_adapter.htm
And I believe the reason you need the adapter is because you bike has separate brake and turn lights.
If you have you changed the rear turn signal lamps to dual filament bulbs this might change the need for the adapter. Otherwise you have to have it.
Check out this page from eglide goodies
http://www.eglidegoodies.com/id262.html
Old Sep 14, 2011 | 07:55 AM
mrjimbo's Avatar
mrjimbo
I would rather Plug an play than splice as well.......
Kuryakyn "plug and Play" ain't so "plug and play"......http://www.kuryakyn.com/Products/174...ring-Harnesses
was sent item 7672 & 7675.....
thanks to your link vtzs4q I think I'd rather use......http://ridetimetechnology.com/trailx.htm
Old Sep 14, 2011 | 09:44 AM
upstate tim's Avatar
upstate tim
Ahmen to the plug and play. I have all LED's too with run/turn/stop/equalize module.
Then I had to add a hitch & wiring. I didn't think I had room either. I got the isolator module from the people I got the hitch from and it was indeed plug n' play and I DID find space along the frame to mount the extra "stuff" out of sight. As I was tweaking my installation and trailer wiring I did pop the isolator fuse so it was doing it's job properly. I think if it weren't for that being installed it would have popped more (important) fuses and possibly left me with no lights and/or burnt wiring.
Good luck, happy trailering
Old Sep 14, 2011 | 10:50 AM
gambler's Avatar
gambler
The main reason is that if something in the trailer wiring goes bad, it will bring down your bike lights as well. If there is an isolator in place, it will limit the damage to only the trailer.
daddybo
Electrical/Lighting/Alarm
Jun 3, 2012 10:38 PM
RoadHog659
Nov 14, 2010 03:30 PM
Big Papa75
Jun 9, 2008 08:09 AM
kpb46
Apr 12, 2008 09:04 PM
CREEPSHOW
Mar 24, 2008 01:23 AM
