Harley-Davidson Street 500 and 750
Engine Guards
Old May 16, 2016 | 10:22 AM
I Surrender's Avatar
I Surrender
4th Gear
Question Engine Guards
Hi. I just bought engine guards/bars for my Street 750 and want to install them myself. There is a plastic cover over the front of the engine area just behind the front wheel. Sorry .... I don't know what this piece is actually called. I have the manual but can't find this piece in it. I need to remove it to install the bars. Before I reef it off does anyone know if this is just attached by grommets as I expect or are there screws or colts I need to remove (I can't see any)? Thanks.
Patti
Old May 16, 2016 | 01:01 PM
Hellbilly562's Avatar
Hellbilly562
Are you talking about the radiator shroud?
Old May 16, 2016 | 01:11 PM
Hellbilly562
Should be 2 allen screws on the bottom front of the radiator guard.....check for the same up top.....might be just two grommets.....I'm looking at pics I took and not at home looking at the bike right now....
Old May 27, 2016 | 11:50 PM
lh4x4's Avatar
lh4x4
I did a short cut. Just get a hole saw off 1" dia. and in the center 1" above the top style grove in panel will allow the bolt to pass through to the recessed threaded area.
I did post it last year and maybe a half dozen other posts like the ride to Sturgis on it. None of the first posts are shown.
Wilbo_1999
Feb 16, 2019 07:22 PM
zlaneb
2014-2024 Touring Models
Mar 11, 2017 01:19 PM
Carrackus
Feb 18, 2014 08:50 AM
kato1964
Mar 22, 2007 01:09 PM
Staceyp413
Aug 29, 2006 06:22 AM
