HDForums Mascot Find out how to be part of the mascot's travels here.
POWER DISSIPATION
Old Apr 23, 2008 | 12:44 AM
jojolucky's Avatar
jojolucky
Stage II
Default POWER DISSIPATION
POWER DISSIPATION
Power dissipation has been empirically determined fortwo representative KEMET series: C052 and C062. Power dissipationcapability for various mounting configurations is shownin Table 3. This table was extracted from Engineering BulletinF-2013, which provides a more detailed treatment of this subject.
Note that no significant difference was detected betweenthe two sizes in spite of a 2 to 1 surface area ratio. Due to thematerials used in the construction of multilayer ceramic capacitors,the power dissipation capability does not depend greatlyon the surface area of the capacitor body, but rather on howwell heat is conducted out of the capacitor lead wires.
Consequently, this power dissipation capability is applicable to other leaded multilayer styles and sizes.
As shown in Table 3, the power dissipation capability ofthe capacitor is very sensitive to the details of its use environment.The temperature rise due to power dissipation should not exceed 20°C. Using that constraint, the maximum permissiblepower dissipation may be calculated from the data provided in Table 3.
It is often convenient to translate power dissipation capability into a permissible AC voltage rating. Assuming a sinusoidal wave form, the RMS ā€œripple voltageā€ may be calculated
from the following formula:
The data necessary to make this calculation is included in Engineering Bulletin F-2013. However, the following criteria must be observed:
1. The temperature rise due to power dissipation should be limited to 20°C.
2. The peak AC voltage plus the DC voltage must not exceed the maximum working voltage of the
capacitor.
Provided that these criteria are met, multilayer ceramic capacitors may be operated with AC voltage applied without need for DC bias.
Old Apr 23, 2008 | 07:16 AM
ckgdrums's Avatar
ckgdrums
Default RE: POWER DISSIPATION
Uuuuuuuh.....thank you?
Old Apr 23, 2008 | 11:04 AM
BiggestDawg's Avatar
BiggestDawg
Advanced HDF Member
Err... I don't think this belongs in this section.
Old Apr 24, 2008 | 06:16 AM
ckgdrums's Avatar
ckgdrums
ORIGINAL: BiggestDawg
LOL... I'm not sure it belongs in this FORUM.
CGLTD
Sep 20, 2016 07:53 PM
Flying low
May 23, 2014 05:41 PM
B.K.
Harley Davidson Videos
Mar 13, 2013 05:24 PM
Certainteed
Mar 31, 2009 10:50 AM
