Help w/fuel pump
Old Apr 15, 2007 | 10:33 PM
Donkey's Avatar
Donkey
Default Help w/fuel pump
Yesterday I installed new handlebars on 2003 FLHRI. I struggled a little with the throttle and Idle cables. Lots of jiggling back and forth. Today when ready to test ride, the bike wont start. All lights work, turn signals work, horn works, starter turns over but it just won't start. I notice that when I turn on ignition I do not hear the whine of the fuel pump. Checked all fuses, none are burned. Looked at all electrical connections I could find relative to fuel sensor/pump.
Is it possible I separated an electrical connection up under the fuel tank? Battery was disconnected for about 24 hours. I have looked in the service manual for all connections under the headlight nacelle where I was tinkering with the handlebars. None seem related to the fuel or starting system.
I also checked for stupid, the kill switch is on, thus the starter turning over.
Any ideas before I resort to dealership?
Old Apr 15, 2007 | 10:44 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Help w/fuel pump
Is your CEL coming on when you turn on the Run switch????
If not, you might have a short in your Right switch housing......
More than likely the orange/white wire......
If it IS coming on, and the pump is not spooling up, check your fuses and the plug to the plate behind the tank console.....
Old Apr 15, 2007 | 10:58 PM
Donkey's Avatar
Donkey
CEL does not come on when I turn to run. I will take the right controls apart tomorrow night. Thanks for the guidance.
michaelbsilvia
Jun 26, 2012 09:37 PM
rlchristensenmd
Apr 17, 2012 11:32 AM
Ohio UC
Apr 18, 2011 09:54 PM
clarkchriston
Mar 3, 2010 09:41 AM
wes
Apr 18, 2006 12:31 PM
