Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hi,
Looking for a map for my 2010 flhtcu with k&n a/c, mgs custom 4" slip ons (standard baffles) bike has HD stage one if it makes a difference.
Does anyone have a map for this set up?
Thanks
Hi,
Thanks
With a PCV the HD stage One download makes a big difference. Is that what you called HD stage one. Need to know as it makes a difference. I have a stage 1 download and stock map to go by.
Went ahead and did couple of maps. Change the .docx to .pvm and they will open in PCV software. Wasn't as much change as I thought it was. Either map should work. The Download map has little less timing in off idle area.
Many thanks for the reply.
Purchased bike in March. Bike had the dealer stage one flash download, k&n a/c, and V&H hi-output slip ons. Orig. owner kept the slip ons and I just added the mgs 4" and also install nightrider vieds. Got gifted the pc5.
Thanks again Louisiana.
Ok I'm computer stupid, how do I change the file...?
Thanks
Ken
I sent you a PM with my email address. I will send the files to you via email and all you will have to do is double click and it will open PCV then just save it to the default directory and you will have it in PCV software.
