little help please
Old May 22, 2015 | 04:30 PM
rufasim's Avatar
rufasim
Default little help please
Riding in this morning I noticed something odd with my bike. 2012 street glide with abs. Every time I started from a stop, as soon as I got to 10 mph, the light on my speedometer would cut out. As soon as I got to 3000 rpm's, the light on the tach would cut out. Both gauges would continue working but with out the light. When I would come to a stop, both lights would come back on and the check engine light would illuminate for about 5 seconds and shut off. Happened this exact sequence time and time again. I think I know what I am doing this week end. Any ideas where to start?
Old May 22, 2015 | 04:33 PM
davidwruth's Avatar
davidwruth
I would start with all the easy basic things. Check your battery check for loose wires and connections especially grabounds.
davidwruth's Avatar
davidwruth
Grounds. Sorry
Old May 23, 2015 | 10:39 AM
rufasim's Avatar
rufasim
Okay, I noticed that when the rpms are brought up, the voltage gauge spikes. Does that mean that the voltage regulator is not working properly. There are several codes but I have not written them down yet.
Old May 23, 2015 | 12:40 PM
davidwruth's Avatar
davidwruth
Good place to start should stay pretty constant
Old May 23, 2015 | 12:42 PM
Ed Ramberger's Avatar
Ed Ramberger
2012 voltage regulators in your model had problems. I would research that first. Overcharging will turn electronics off as well.
Old May 23, 2015 | 01:00 PM
nhrider1's Avatar
nhrider1
ED R is correct. Lots of problems with intermittent voltage regulators in 2012. Check the codes you are getting.... If its the voltage regulator you'll have high/low voltage faults.
Old May 23, 2015 | 01:24 PM
rufasim's Avatar
rufasim
I had the voltage regulator changed on recall. If this is the problem then this will be the third one in there
Old May 23, 2015 | 01:37 PM
rufasim's Avatar
rufasim
Codes are as follows:
B0563, B1006, B1007,
Couple others but those are for the O2 sensors I no longer use
Old May 23, 2015 | 04:31 PM
rufasim's Avatar
rufasim
and p0563
