Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Does the Tc 88 Efi have an air intake temperature sensor?
If so was thinking, would it be possible to put a resistor in line with it so as to trick the ecu into thinking it is cooler than it really is, and in that way richen up the mixture a bit?
Would want this especially after fitting more free flowing pipes and air filter.
Putting a resistor in line with the intake air temperature instead of having to remap the ecu?
