Auto Tune, how does it work ?
Old Nov 27, 2015 | 12:33 PM
Diamondjim722's Avatar
Diamondjim722
6th Gear
I really don't know that much about efi tuning but my bike had a lot of deceleration pop and it was annoying so I went for the power vision and the target tune. I got it from fuel Moto they were great the map they installed got rid of 95% of the popping so I'm hoping that when I auto tune I can get rid of the rest.
Old Nov 27, 2015 | 12:41 PM
Uncle Larry's Avatar
Uncle Larry
http://www.enginebasics.com/EFI%20Tu...%20Basics.html
Old Nov 27, 2015 | 01:04 PM
Diamondjim722
6th Gear
Thank you
Old Nov 27, 2015 | 01:10 PM
Johhny51273's Avatar
Johhny51273
Excellent thread gentlemen. Just got a power vision myself, great info.
I had a stage I downloaded by the stealer with my a/c install so the bike was already running better. Installed some different slip ons recently and had some decel pop. Loaded the tune suggested by Roy @ dynojet and its running better but want to go through the auto tune process when the weather clears.
What is the best way to fill as many cells as possible during the AT sessions?
Old Nov 27, 2015 | 01:18 PM
Diamondjim722
6th Gear
I would be interested in that answer myself. Very good question.
Old Nov 27, 2015 | 01:28 PM
JustDave13's Avatar
JustDave13
Originally Posted by Dave Cawley
What would make you think it isn't operating in closed loop at 14.3?
Because if it was, the ECU would adjust the VE and make any Auto Tune redundant ?
The ECU doesn't adjust the VEs, the purpose of auto tune is to get you VEs dialed in with the tuner, (it's the tuner that does this not the ECU). Once you've set them you flash it to the ECU as part of the tune and that's where they stay.
The VEs are basically set, they are the foundation for your tune.
When operating in closed loop (14.2-15.0) the ECU gets feedback from the 02 sensors to make sure that the right amount of fuel is delivered to a cell that is in closed loop.
Parts of your tune will not be in closed loop, when you get a canned map a good percentage of the tune will be in open loop.
In open loop the ECU uses the VE settings to calculate the correct amount fuel for those open loop cells.
If one or both of your 02 sensors were to fail the ECU will automatically fallback on the VEs to set the correct fuel in those areas where the ECU was once getting feedback.
The VEs also set a beginning reference point where the tune will start.
The VEs are also used when engine is cold and the 02 sensors haven't reached operating temperature.
Keep in mind that the tuner is used to create the map, the map is a set instructions which are carried out by the ECU. The ECU doesn't really change anything on the map (though there is a slight rounding of numbers that have been know to take place during the flashing process).
Old Nov 27, 2015 | 04:27 PM
Dave Cawley's Avatar
Dave Cawley
Originally Posted by JustDave13
The ECU doesn't adjust the VEs.
It must do in closed loop ? Otherwise what closes the loop ?
But all my questions still stand :
So Auto Tune :
What does it do ?
What does it alter ?
How/what does it sense/detect, so that it makes the changes ?
Old Nov 27, 2015 | 05:34 PM
JustDave13's Avatar
JustDave13
Closed loop is when the ECU incorporates the 02 sensors for fuel metering.
Open loop is when the set afrs are out of the range of the 02 sensors (an example would be 13.8).
What closes the loop would be the settings on the map.
Maybe you missed this.
What it simply does is add or take away fuel until it reaches the desired 14.7, then using injector pulse time the software calculates how much air your engine is passing at that given moment. (this is why you want to hit as many cells as possible)
This is how it figures the VE ratios (how much your engine breathes) which are the most important numbers for setting up an accurate tune.
Without accurate VE numbers as a foundation your tune will be off.
Old Nov 27, 2015 | 08:11 PM
whittlebeast's Avatar
whittlebeast
See if this helps.
http://www.nbs-stl.com/tuning/BasicTuning101.pdf
Andy
Old Nov 28, 2015 | 02:27 AM
Dave Cawley
Thanks guys.
In which case, what is the Auto Tune sensor/measuring to set VE if the O2 sensors are out range?
I'm still looking for my answers. I am a skilled electronic design engineer, that's why I really want to know.
Any more input welcome. BTW I never trust Google, only acknowledged experts in their field.
