Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
But everyone here says they are when not in the 14.6 - 14.7 range, are you saying different ?
Auto Tune only creates part of your tune, when you are done auto tuning you incorporate the results into your tune/map.
That's auto tune basic using the factory narrow band 02 sensors.
There are other auto tuning setups out there that use broad band 02 sensors that have to be installed on the bike.
Here is a plot that we can all use to help explain autotuning in the Harley world. You have to keep in mind that NB O2 sensors are only good at finding 14.7 AFR (for some reason the Harley world uses the number 14.6) Either way they mean Stoich. Or right at the edge of there is still some O2 in the exhaust or there is no O2 left.
On the left of this screen shot is a scatter plot showing the O2 voltage with most of the samples are either shown as near .2 volts or on the lean side of 14.7 AFR. There is also many red dots indicating near .8 volts or richer than 14.7 AFR.
Keep in mind that this motor is running most everywhere in open loop. The ECU in this example is only logging the RPM, MAP and O2 voltage.
On the right is the same data rolled up into RPM by MAP boxes. Blue areas indicate lean averages. Pinkish boxes indicate the the AFR averaged rich.
Boxes that averaged real close to 14.7 AFR show up as green or have an average voltage of real close to 14.7 AFR or real close to .5 volts average.
We will talk about the larger colored boxes a bit later....
In simple terms, what an autotune does is locate areas that are clearly blue and add some fuel in those areas. It also looks for the areas that are clearly red and pull a little fuel from that area.
Right now I am messing with Target Tune. Generally, I start by using the Autotune software as intended by the manufacturer. I then use MegaLogViewer HD to verify that the Autotune SW is working as advertised. If I like the SW I like to help other people learn to use the SW. If it does not work as advertised, I get back to the manufacturer as to what is not working as advertised.
I tend to hand tune all tunes once I identify the limits of the system. All hand tuning is done based on what I learn from MLV HD.
All autotune systems generally work on the same tuning principals. Adjust the VEs to hit the target AFRs.
