vied's
Old Dec 14, 2015 | 06:03 PM
flashman58's Avatar
flashman58
Default vied's
just picked up a set of used VIEDS for my 07 roadglide, noticed that the adjustment dial is kinda vague with the settings and that the wheel moves real easy, does not click in at any of the settings.If you have or have had themI was wondering if this is the way they are supposed to be or maybe I didnt get as good a deal as I thought I did.
installed them and put them to were I thought was the minimal setting and noticed better throttle response through the gears, so hoping they are all good.
Thanks
Flash
Old Dec 14, 2015 | 06:17 PM
MURPHCC1's Avatar
MURPHCC1
Had mine on a 07 Ultra.......yes that little dial moves quite easily but thats ok.......If i remember correctly I had mine set about 75%......was a cooler engine and better response......loved them!!
Experiment with settings.......you'll find a sweet spot......
Old Dec 14, 2015 | 06:24 PM
flashman58's Avatar
flashman58
Great thats what I was hoping to hear, will play with the settings and search for that sweet spot.
Thanks
Old Dec 15, 2015 | 05:33 PM
Rubline's Avatar
Rubline
When I was using them, I would set the dial at 75% and wrap it with electrical tape.
Old Dec 15, 2015 | 06:08 PM
hardheaded's Avatar
hardheaded
i've been running mine at 50% and 25%, depends on your setup what will work the best.
Old Dec 15, 2015 | 07:18 PM
flashman58's Avatar
flashman58
stock air cleaner with K+N filter and rinehart slip-ons
Old Dec 16, 2015 | 09:34 AM
hardheaded's Avatar
hardheaded
if you are still running the cat you can run at alittle higher number, if running non cat you have to turn them down a bit because of revertion.
Old Dec 16, 2015 | 06:16 PM
flashman58's Avatar
flashman58
ok, cats still in, will play with settings in the spring, just about ready to wrap it up here in the northeast. although 50's and 60's in december has been nice
Old Dec 16, 2015 | 06:52 PM
hardheaded's Avatar
hardheaded
we ride all year as long as the temps. and there isn't any salt on the roads. so far this winter has been pretty good.
Kave Dweller
Audio Systems
15
Sep 4, 2014 09:25 AM
flapjack
Apr 6, 2010 01:58 PM
HarleyLew
Apr 4, 2008 04:06 PM
