diag. code
Old Feb 18, 2016 | 08:22 PM
murmax21's Avatar
murmax21
Stage I
Default diag. code
I am pulling up diag. code p0501 vss sensor low. anyone know what that is? its on a 2008 ultra
Old Feb 18, 2016 | 10:18 PM
Bingee's Avatar
Bingee
The VSS is the vehicle speed sensor. Is your speedometer working ok? Maybe the connector is loose or not plugged in all the way. It's under the starter on the transmission.
Old Feb 18, 2016 | 10:19 PM
Vernal's Avatar
Vernal
Welcome to the forum!
The VSS is the Vehicle Speed Sensor, it gets a signal from the teeth of the 5th gear. It sits below the starter. I believe you need to pull the starter to get to it. I have the manual for that year and it says to check the connector that is right at the VSS and to pull the VSS and clean and inspect the face. Clear the code and ride for a mile and see if it comes back. If it does start ohming out the wire to the ECM.
Post your email address and I'll send you a copy of the procedures to check it all out.
Good luck
Bill
big- mike
Feb 25, 2017 02:17 PM
RKDude58
Jan 27, 2016 07:48 AM
stilup
Jun 1, 2011 08:07 PM
kmm4444
Sep 1, 2010 07:56 AM
AZCFH
Mar 15, 2010 01:21 PM
