Crank Case Sensor Intermittent Code
Old Aug 30, 2010 | 10:03 PM
kmm4444's Avatar
kmm4444
6th Gear
Default Crank Case Sensor Intermittent Code
I am having start up problems on a 2008 Street Glide with stage II engine. Checked trouble codes and CKG sensor intermittent code was revealled. Can a faulty crank case sensor cause problems with initial engine start up?
Old Aug 30, 2010 | 10:40 PM
stevelonewolf's Avatar
stevelonewolf
Yes it can.
Old Aug 31, 2010 | 01:19 PM
95custmz's Avatar
95custmz
It will cause bike to run with rough idle if it starts or will cause backfire.
Old Sep 1, 2010 | 06:43 AM
kmm4444's Avatar
kmm4444
6th Gear
Thanks for the info and response. I replaced the sensor and it helped. I am still having noise with starter. If I bump it then it will start. I think my next project will be to rebuilt starter with a stronger starter cluth.
Old Sep 1, 2010 | 07:56 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by stevelonewolf
Yes it can.
+1 absolutely
crabclaws1
16
Aug 31, 2017 06:55 PM
murmax21
Feb 18, 2016 10:19 PM
RKDude58
Jan 27, 2016 07:48 AM
roundman327
Jun 15, 2012 12:42 AM
AZCFH
Mar 15, 2010 01:21 PM
