poss crank sensor???
Old Mar 15, 2010 | 12:59 PM
AZCFH's Avatar
AZCFH
Default poss crank sensor???
hi hope i can get some help. went to start my bike this am started to crank over then stopped then starter just clicks.. when i get home i will double check the connections to batt, starter,fuses,etc.. did do a quick check for codes thru the speedo got (pn 68920-07) tried googling that code .it says a crank senor is the part num. long story short could that cause loss of sig to starter ckt? like i said will check connections when i get home had to get to work any thoughts thanks...
Old Mar 15, 2010 | 01:09 PM
dawg's Avatar
dawg
68920-07 is just the pn# for the TSM which is what you are checking the codes through. There should be a code like other than a pn# if you have any codes, like P0373 etc. With the 2007 I would consider looking at the service bulletin M1231 on the 2007 starter issue as well as checking the connections and relay.
Old Mar 15, 2010 | 01:21 PM
AZCFH's Avatar
AZCFH
ok thanks dawg i'll check to make sure the bolts are tigh and i'll recheck the codes hope the bolts are just loose. it was weird that it cranked over and now the starter just clicks but if my ground is no good tha makes sense .. if it indeed is a crank sensor do you know how much they are roughly..thanks again
murmax21
Feb 18, 2016 10:19 PM
RKDude58
Jan 27, 2016 07:48 AM
roundman327
Jun 15, 2012 12:42 AM
roundman327
Jun 14, 2012 10:46 PM
kmm4444
Sep 1, 2010 07:56 AM
