help needed just replaced starter now check engine light code 42
Old Jun 14, 2012 | 10:02 PM
roundman327's Avatar
roundman327
Default help needed just replaced starter now check engine light code 42
i recently had a starter take a crap on my 2000 flstf due to it hanging up and riding on the flywheel, i replaced the starter, filled all my fluid back up started the bike to check for leaks and engine light comes on for about 8 seconds after running and goes back out, performed the pin 1/2 procedure to check fault code, getting fault 42 for cam position sensor, any ideas of why all of a sudden this has come up had bottom end built 5k ago with same fault due to faulty tensioner and clogged oil pump have had no issues till now, any help would be appreciated, im out of warranty and on a budget thanks, dusty
Old Jun 14, 2012 | 10:32 PM
im's Avatar
im
historical code?
maybe disconnect both battery terminals to clear and monitor for return.
Old Jun 14, 2012 | 10:54 PM
oct1949's Avatar
oct1949
There is a low and high sensor and the 48 is the high one... wished I knew what the diff was, but I dont.
Old Jun 15, 2012 | 12:42 AM
kkiley's Avatar
kkiley
It fired backwards on a start and threw the code, it happens. Its historical now so its not an issue
widey
Jul 4, 2024 03:17 PM
roundman327
Jun 14, 2012 10:46 PM
stilup
Jun 1, 2011 08:07 PM
kmm4444
Sep 1, 2010 07:56 AM
AZCFH
Mar 15, 2010 01:21 PM
