2012 Street Glide ECM Module
Old May 7, 2016 | 07:43 AM
Redneck23's Avatar
Redneck23
Stage II
Default 2012 Street Glide ECM Module
I just installed a home made air ride system. The pump is from an 88 cadilac which has its own storage tank and dump valve built in. So it is very large. I don't have anti lock brake system so I was going to install it in that area. In order to do so I had to relocate the ECM module. I placed it horizontally between the pump and storage tank. Started the bike and it ran for about 15-20 seconds.. On my odometer it read t1 P. After going over the entire system and up till 3:00 am, still no luck. Ran the codes all came back none!!!! Woke up this morning to review my work and the only major change was the ECM from vertical to horizontal. Held it vertical by hand and every thing works fine until I lean it sideways. WHY and how do I bypass this problem??????????????
Old May 7, 2016 | 08:05 AM
scooterbum46's Avatar
scooterbum46
Is the tip sensor part of the ECM? t1 P could say "TIP"
Old May 7, 2016 | 04:08 PM
Redneck23's Avatar
Redneck23
Stage II
Default T1 p
Thanks a million that was the problem. It is part of the unit that turns off your turn signals after a turn and will shut the bike down after being greater than some???? angle after 15 to 20 seconds. Another guy I spoke to said these units can also go bad. His friends bike would die after a right hand sweeping turn but never to the left. It was found to be this unit that failed.
UFO8MyCow
General Topics/Tech Tips
Apr 6, 2016 12:55 AM
Patgreyling@hotmail.com
Harley-Davidson Street
Jan 17, 2016 03:24 AM
paid4c4
Mar 30, 2015 12:06 PM
jake8200
Jul 15, 2007 04:46 PM
mroadking
Sep 14, 2006 10:25 AM
