Alternator output
Old May 28, 2007 | 11:50 AM
fb4u2nv's Avatar
fb4u2nv
Default Alternator output
Does any one know the output of a stock alternator on a 98 Road Glide EVO?
Just wondering how much stuff I can put on the system>
Old May 28, 2007 | 12:14 PM
ZD's Avatar
ZD
Default RE: Alternator output
ORIGINAL: fb4u2nv
I'd guess a 32 ampsystem...
My '99 Heritage Evospecs showa 32 Amp system whichcharges (theoretically) at the following rates:
1000 RPM - 15 Amps
2000 RPM - 26 Amps
3000 RPM - 30 Amps
4000 RPM - 31 Amps
5000 RPM - 32 Amps
Old May 31, 2007 | 09:13 PM
thelawdoc's Avatar
thelawdoc
Well, what I cannot understand when matching alternator output with the loads on the bike is this: I added the fog lamps and accent lights to my new '06 Deluxe, and in the winter months I use all heated outerwear. Everything calculated out fine with the alternator, but recently my voltage regulator died. Mechanic said I worked it to death, but they replaced it under the warranty. I am scratching my head trying to figure out how to prevent this in the future. Seems to me that it is not enough to have ample current from the alternator for your accessories, but that you need a regulator that can deal with it also. Or, is my dealer mechanic wrong? I am going nuts over this question and I will be forever indebted to anyone who has an answer for me. My understanding is thataccessories added onto a bike reduce the work of the regulator, especially regulators that operate by shunting. The only thing I can think of so far for ruining my regulator is perhaps the warmer weather overwhelmed the air cooled fins. There are other regulators out there that purport to be better than the conventional ones, e.g., from Crane [The Fireball] and from J&P Cycles. Has anyone replaced their HD regulator with another?
Old Jul 17, 2009 | 09:48 AM
tritonpete's Avatar
tritonpete
Stage I
Default alternaror autput thelawdoc
your rectefier starts dumping electric when your alternator output is more then you are using,running the bike and charching the bat. it turns energy into heat (cooling fins) is it well earthed?clean the nuts ,fitting to frame also you can try riding with your lights on soory abaut my english i am german and live in south of france i get confused with all the languages can you get good second hand (used) h-d parts where you are spares are verry- exspencive here ride safe pete
Dave Bell
Aug 10, 2016 10:20 AM
i Confederate i
Panhead
Aug 20, 2014 08:13 PM
dcelaya
Nov 4, 2012 07:11 PM
RENORRIS
May 26, 2012 06:29 PM
fcast4
Dec 6, 2007 02:24 PM
