Do i need a programmer?
Old Aug 31, 2017 | 11:12 PM
wot618's Avatar
wot618
Default Do i need a programmer?
I am struggling with this whole programmer deal. I'm not sure which way to go looking for a little help. I don't want to spend a whole lot once its set up I wont be making any changes. I have a 05 flhti with a 95" piston kit air cleaner hooker tuned flow slipons and planning on putting on a set of s&s power tune duals. bike was flashed from Harley. Do I need a programmer if I'm changing head pipes?
I appreciate any advice
thank you
Old Aug 31, 2017 | 11:26 PM
GroovusMagnus's Avatar
GroovusMagnus
Any time you change the airflow, you need to adjust the fuel mixture. Do you need a tuner for that? No, another dealer flash should work, but I'd rather do it myself with my own tuner.
GM
Old Sep 1, 2017 | 01:10 PM
nevil's Avatar
nevil
The flash is just a canned map, guaranteed to run lean. The way to get the most power and driveability is with a tuner that can be dialed in to your particular set up.
Old Sep 2, 2017 | 11:20 AM
FLTRI17's Avatar
FLTRI17
A power commander 5 will do just fine for you and there are starting maps available that make the engine run better albeit on the rich side.
After you save up a bit get it tuned properly for best performance and mileage by a qualified tuner and you will not be happier.
If you intend to do more engine mods (i.e.: cams and displacement) I recommend a proper flash tuner (no add-on box) and a tune that will produce a better running bike than a p/c.
Bob
pdevore
71
Mar 22, 2016 07:19 PM
lateralus
Feb 21, 2013 07:50 PM
black switchback
Nov 27, 2012 07:25 PM
Cdf187
Nov 17, 2012 09:53 AM
4srco2
Exhaust System Topics
Apr 17, 2012 12:22 AM
