How to open throttle plate on drive by wire models?
Old Nov 6, 2017 | 01:54 PM
martin10's Avatar
martin10
Default How to open throttle plate on drive by wire models?
Bikes with drive by wire throttle body. How do you open the throttle plate? Thanks.
Old Nov 6, 2017 | 04:03 PM
grbrown's Avatar
grbrown
With your fingers after removing the air filter, but why do you ask?!
Old Nov 6, 2017 | 04:39 PM
martin10's Avatar
martin10
Wasnt sure if that would damage something. Wanted to ask before I tried it. I gently pressed on the throttle plate and it didn't seem to want to move.
Old Nov 6, 2017 | 09:02 PM
bustert's Avatar
bustert
by federal reg, the throttle must be spring return if the circuit is broken.
the tps and plate act like a wheatstone bridge. a wheatstone bridge will always try to find balance so if the tps sends 3volts out, the plate will move till the it balances out at 3 volts, once they are syn, they stay put. remember the old outdoor antenna rotors, same principle.
matte
Jun 24, 2015 04:29 PM
TexasFLHX
Jun 12, 2015 11:04 PM
user 46092
May 18, 2015 12:52 AM
JC0311
Touring Parts
Feb 15, 2015 08:32 PM
SM49
Jun 6, 2012 06:15 PM
