Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I just made my last autotune run and "finished" the autotune. I uploaded it and then went back into my "autotune modified" canned map. I then changed the idle RPM and REV limiter in that map.
My question is... Did I screw up my uploaded/finished autotune when I changed the MAP's rev/idle? Hopefully not...
I don't think you messed up the map... your upper RPMs, at the new red line, would not have been autotuned. But most likely you would not have autotuned that area anyways.
I would run it. Worse case you run a few more autotunes.
Thanks, the small amount of the RPM scale that I've missed is pretty insignificant, especially at those RPM levels. I'll probably touch base with V&H tech tomorrow just to make sure. I was thinking the same as you though...
