code error
Old Feb 27, 2018 | 04:28 PM
josecodes's Avatar
josecodes
Stage III
Default code error
code 61154 how i can solve it ?
Old Feb 27, 2018 | 04:44 PM
shanneba's Avatar
shanneba
DTCs B1154 and B1155 will set when either the clutch switch
circuit or neutral switch circuit is shorted to ground at speeds
greater than 10 mph (16 km/h) for more than 60 seconds.
See link below to find the wiring diagram for your Harley-
Old Feb 28, 2018 | 07:59 AM
Ed Ramberger's Avatar
Ed Ramberger
Start by introducing yourself to the forum before just throwing out the above for your first post.
Old Feb 28, 2018 | 09:23 AM
jbarr1's Avatar
jbarr1
Why is an introduction required to answer a straight forward question?
I’ve seen that code when riders pull in the clutch at highway speed and coast when exiting the highway. Not a good thing to do but that’ll set the code.
Old Feb 28, 2018 | 10:27 AM
josecodes's Avatar
josecodes
Stage III
[Quote = Ed Ramberger; 17134505]. Comience por presentarse al foro antes de simplemente tirar a cabo lo anterior para su primer post [/ quote]
Old Feb 28, 2018 | 10:30 AM
josecodes's Avatar
josecodes
Stage III
sorry , i'm from Argentina, my english is not so well . My name is jose codes I live in Mendoza, ARgentina, i have two HD one Dyna 00 and Street glide 2010.
Old Mar 1, 2018 | 08:31 AM
Ed Ramberger
Did you change levers or are you coasting with the clutch pulled in (as asked above)? I read a post by a person who changed levers and the micro switch wasn't activated properly by the new lever and it set the code.
tootal
Electrical/Lighting/Alarm
Nov 26, 2018 03:58 PM
Bluesrider.df
Apr 4, 2018 07:44 PM
JT48
Jul 16, 2017 02:59 PM
SixSixRider
Jul 20, 2010 04:04 PM
pip369
Aug 19, 2009 09:12 PM
