FP3 autotune question.
Old Apr 23, 2018 | 04:44 AM
Gordon61's Avatar
Gordon61
Vance and Hines suggested
  • enter autotune
  • get plenty of hits
  • hit Apply
  • hit Apply
  • hit Finish
  • save Finished tune into a slot
  • Done.
So that was a total of 3 separate autotune process/run/session/series of learned cells on the hits screen/call it what you want
ADD: if you want to... you could do this two times, and have two saves tunes. Then manually compare the VE tables between them to see how much difference there is between them. Not much difference then you are probably as good as you will get. Don't be surprised to see some differences tho, and this is the bit about chasing your tail
Old Apr 27, 2018 | 10:10 PM
Idahokid's Avatar
Idahokid
So I ran a few autotune session and finished.I thought I would see a difference in A/F ratio but the map for my set up and the autotune map have the same exact numbers box for box. I thought I would see a difference?Seems to run a little more responsive.Maybe my imagination?
Old Apr 28, 2018 | 04:21 AM
Gordon61's Avatar
Gordon61
"autotune" doesn't do anything other than try to work out what your VE tables should be.
Deciding on your AFR table is a manual thing that comes later in the tuning process ...if it needs to be changed at all. Different people pick different numbers for different reasons.
If you are tuning one of the V&H maps then they have already changed the AFR table to 14.3 everywhere low load and 12.9 everywhere else (or along those kind of lines) - leave it like that.
If you have tuned a copy of your stock map then you will still have the stock AFR table - download a V&H map (doesn't really matter which one, their AFR tables are all the same for your bike) and save it in a different slot, then manually set your AFR table to be the same as the one you downloaded.
Old Apr 28, 2018 | 07:36 AM
Idahokid's Avatar
Idahokid
Thank you for the explanation.I guess I was under the impression that it would be different.I seem to have picked up in the mid and upper end.I think I’m going to leave it where it’s at.(Chasing my tail)
firehawk6
Vance & Hines
Jul 15, 2019 09:19 AM
Old Rust
The Dyno Room
Jul 28, 2017 08:55 AM
Surfcitydude
Vance & Hines
Apr 17, 2017 01:37 PM
jimski
Aug 28, 2010 10:15 AM
spider445
Oct 23, 2007 10:20 PM
