Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
it would cost MORE in octane booster than to just buy the fuel. read the bottle. what you get is .1 (one tenth) which they call a point, it is NOT one whole octane number.
I can get a 2 oz. bottle of Lucas octane booster (the best IMO) at my local indy for $4.00. That’s enough to treat one tank. My tank holds 5 gallons. Do the math. The octane booster would cost me $.20 more than the 93 octane. If I had a 6 gallon tank I could save $.56. Big whoop. I think I’ll just fill it up with premium and ride.
Many octane boosters only raise tenths of a point, not entire points. Just buy premium and be done. In reality, if a person can't afford an extra $3 for a tank of gas, they can't afford to ride.
just to say:
i run a 2001 xls with over 10:1 and run the lowest octane fuel around here and ZERO issues. my camming allows for it since dynamic compression is low enough for the fuel. i did have clutch off issues but i retarded the timing and trashed the voes and run rpm base adv timing. do i lose anything, my butt dyno says no but a true dyno might differ. now i also have issues when they do the seasonal fuel blends. but by far and large, i run swamp water.
just to say:
Big difference in weight, load and heat between an XL and a touring bike.
the point was, tune for it. i bet mine isn't far off from your bagger on take off, i pull a very tall gear. also, with retarded camming, it really doesn't come to life till you cross 4k. the power band is shifted around 500 rpm up scale. i dropped around 5* on ignition so the ping went away mostly, only when ambient is hot. still can drop timing to 20* if needed with dual plugs, lead is such as important. i lose the speedo when i drop third out, cruises 120 @ 5k. still 2.5 to go.
