Cel
Old May 23, 2018 | 12:27 PM
FLTRI17's Avatar
FLTRI17
Originally Posted by rydahog
Here is my speedo.with codes..the one with d055et cleared, but not the d025et.
EFI ? Carbureted? Ignition mfg?
why not provide the info asked for?
Bob
Old May 23, 2018 | 12:31 PM
rydahog's Avatar
rydahog
2001 fxdwg, carb. Delphi ign.
Old May 24, 2018 | 11:05 AM
FLTRI17's Avatar
FLTRI17
How does your speedo work? Looks like do2 and do5 are speedo failure codes.
Bob
Old May 24, 2018 | 07:28 PM
rydahog's Avatar
rydahog
Replaced speedometer and it's fine now, speed ok, odometer fine, and now self cancel turns work., they didn't with old speedo... I was able to clear code D055et on old and new speedo. But not able to clear code D025et.?.. That's one issue, after I installed this used speedometer, bike ran fine for 1 mile, then rough idle, trying to stall. No CEL.. So i replaced the coil and bike runs great, but now cel stays on.? I put back old coil just to check, and no CEL, but bike runs like crap.. Is it possible new coil was also bad? Plugs are nice and clean. New wires.
Old May 25, 2018 | 11:52 AM
FLTRI17's Avatar
FLTRI17
FWIW:
“d02 Speed sensor power output shorted high or open” (red wire)
If the bike runs good with one coil and not the other my suspicion the working coil is not for your bike model?
AFAIK:
There is no connection between the speedo function and run quality...other than idle as the ECM needs to know if the bike is stationary (one idle routine) or moving (another, higher rpm idle)
This is way more difficult than it should be IF the replacement coil is known to be good and the correct p/n for the application.
Bob
bigben46
Jun 15, 2015 11:06 PM
colwell
May 10, 2015 10:32 AM
rider123450
Mar 9, 2012 10:14 PM
Proudtexan
Dec 29, 2010 05:51 PM
zenwarrior
Sep 13, 2006 01:17 PM
