ignition problem
Old Mar 6, 2012 | 12:34 PM
rider123450's Avatar
rider123450
1st Gear
Angry ignition problem
have an 01 ultra 60,000 miles. tried to start and no go. No fire at plugs, lifted tank to get to coil and have no 12 volts to coil. fuses good.
Old Mar 6, 2012 | 04:48 PM
ajayrk's Avatar
ajayrk
Did you check the ecm fuse under the right side cover. Also could be the crank position sensor.
Old Mar 6, 2012 | 05:17 PM
rider123450
1st Gear
all fuses good
Old Mar 6, 2012 | 05:24 PM
soft 02's Avatar
soft 02
Could be debris on crank sensor? Is there a relay for the coil?
Old Mar 6, 2012 | 05:50 PM
ajayrk's Avatar
ajayrk
Read through this thread:
https://www.hdforums.com/forum/elect...on-sensor.html
Old Mar 9, 2012 | 07:42 PM
rider123450
1st Gear
checked diagnostics thru my speedo...replaced my crank position sensor, took me about an hour, bike runs. thanks for your help. $58.00 from the dealer
Old Mar 9, 2012 | 10:03 PM
ajayrk's Avatar
ajayrk
Old Mar 9, 2012 | 10:14 PM
soft 02's Avatar
soft 02
With the amount of miles on mine I think I will replace that sensor. You never know.
RanHow
Ironhead
Sep 9, 2017 08:36 AM
dog155
EVO
Aug 8, 2017 08:35 PM
bigben46
Jun 15, 2015 11:06 PM
kathygill12
Jul 20, 2010 11:08 PM
djfugate623
May 12, 2009 07:54 AM
