Target tune
Old Sep 15, 2018 | 10:23 PM
rsking45's Avatar
rsking45
Default Target tune
Who is using it and is it worth the money?
Old Sep 17, 2018 | 07:29 PM
misfitJason's Avatar
misfitJason
Yes it is
Old Sep 23, 2018 | 11:43 AM
1 2 many's Avatar
1 2 many
Not sure If it's worth it. But I am sure it helps hold my afr were they need to be .
Old Sep 23, 2018 | 04:59 PM
donk_316's Avatar
donk_316
? Doesn't every tuner "hold AFR where you want it"?
Old Sep 28, 2018 | 11:41 AM
FLTRI17's Avatar
FLTRI17
Target tune is to be added to an already tuned bike. The stock ECM and sensor provide all the info to keep a tuned bike in tune with any other systems or sensors. To believe another system is necessary to keep a tuned bike in tune is simply believing marketing at its best.
Bob
Old Sep 28, 2018 | 11:48 AM
MURPHCC1's Avatar
MURPHCC1
so whats the difference between Target Tune and Auto Tune Pro?
Old Sep 28, 2018 | 03:29 PM
hrdtail78's Avatar
hrdtail78
One is made to map the VE tables to center the trims. TT is used to replace the stock, fast acting sensors with slower sensors that get dirty and drift. Nothing in the car industry uses 4.2 at all. Let alone in this way where they were never meant to be used.
Old Sep 30, 2018 | 08:57 AM
MURPHCC1's Avatar
MURPHCC1
yea.......that makes no sense..........didn't answer my question.........
wth does 4.2 mean in all this??
you say "One is made to map the VE tables to center the trims"......and the other one?
Old Sep 30, 2018 | 09:46 AM
springers4ever's Avatar
springers4ever
Cool Target tune ....
When using the powervision alone with the stock 02 sensors the ecm will only control in the 14.1 -14.7 range....as stock does ....when used w/o the 02 sensors ...the ecm runs like a carb bike with no feed back and no conrtol of the fuel ...
when running the target tune with the powervision and the wide band 02 sensors ...the target tune module reads the 02 sensors ...stores this data and re-range's the data in a state (the stock ecm can read ) in order to control the afr in a wider range ....(as the stock ecm still and will never be able to control outside of the 14.1 -14.7 range)
if you run the Powervision w/o target tune the bike will run as a carb bike would ...when anywhere outside this range ...
so ...w/o target tune and the wide band sensors ...you will have no control of the fuel at higher or lower altitudes ...as you go higher the bike will run richer (thin air) ...and if a little to rich to start ...may foul plugs before you get up there ..!!!(depending on how high you go ) ....
but the idea is to be able to add more fuel in the lower throttle openings to help reduce heat ...
but from what we hear now ...EPA is going after all the aftermarket tuners now ....so ...soon they will not be able to help you neither ...(as Harley is doing now after their big fine they had to pay ) ...
Old Oct 2, 2018 | 09:58 AM
KumaRide's Avatar
KumaRide
Their are many threads about this with input from well known professionals who write the code for a living and tune for a living. Here is my "simplistic" and "general" take away on NB, WB, AT Pro and TT, after reading those threads for a couple years.
NB are best up to 3500-4000 rpm. WB are best above that. Fuel Moto mentioned in a post that they tune with the stock NB's up to ~3500 rpm range. And use WB to tune above. We ride 95% of the time below 4000 rpm which is where NB are best. Given that, some use AT Pro, tuning with both NB and WB. This provides the tuning in upper and lower rpms. And, keeps NB on the bike as they are best below 4000 rpm. This circles back to what Bob LFTR117 and Hardtail78 said. NB are the way to go once you have a good tune.
Note: TT, AT Pro, NB or WB can NOT fix or adjust timing issues.
Pudge211
The Dyno Room
Dec 20, 2018 08:37 PM
Erilflynn
Dec 5, 2018 08:34 PM
Christopher.z.webb
Milwaukee Eight (M8)
Sep 30, 2018 04:57 PM
CheneyColin
The Dyno Room
Jul 14, 2018 12:19 PM
Z
Jun 29, 2018 09:31 PM
