Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Stock 2017 FLHTCU Had the 15,000 mile service along with ABS Brake Flush and Clutch Actuator Recall performed. The Dealership also Downloaded the latest ECM update # 41000477C/DT. Does anyone know what this update does? Fuel Management, Idle change, Different Fuel Map? Engine seems to run better, idle does not appear to have changed; however, have not had a chance to run it in warmer weather or check the MPG. Mostly curious on what the update changed in the ECM. Thanks for any info on this non-important matter.
You might check your VIN on the Harley Service Information Portal to see it shows any update info-
After you search by VIN-
click on the Vehicle Documents then check "Service Bulletins" https://serviceinfo.harley-davidson....cle/lookupForm
The latest update to the Pro Street Tuner software has this about 2017-2019 models.
I do not know if that is exactly what your update covers.
Software Enhancements:
RPM Limit adjustment has been added to the Tuning Tables for 2017, 2018 and 2019 models that support time based RPM limit.
