Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Is the procedure for the Smart Tune feature the same as the discontinued Race Tuner? Found some very detailed instructions for the Race tuner and wonder if they should work. Thanks in advance.
This Cam set is a bolt in cam BUT, do I even stand a chance of being able to install this set of cams and getting the bike running enough to get it to a Dyno shop (NOT NEAR BY!)
using the Screamin Eagle Pro Super Tuner? or am I just going to have to buy a different tuner to do this?
How many threads are you going to ask the same thing? It's so simple a monkey could do it and I even told you which base cal to use that would do just fine to get you to a tuner. All you had to do was load it.
