sportster won't start, no lights, etc.
Old Sep 17, 2012 | 08:00 PM
Scubamob's Avatar
Scubamob
2nd Gear
Ok got it after checking every thing other than the ignition switch. It ripped it out and hot wired it and it worked. So if you got these symptoms try going there first unlike what I did. Hope this helps some body
Old Sep 17, 2012 | 08:26 PM
Scubamob's Avatar
Scubamob
2nd Gear
Oh any advice on a new ignition switch. Are the round keys any better?
Old Jul 8, 2020 | 04:56 PM
Sterge's Avatar
Sterge
Stage I
Originally Posted by motochick218
I rode my 96 1200 sportster home from work yesterday, no problems. I came back out 15 minutes later to put it in the garage. I turned on the key but just the odometer light came on and nothing else, no oil light, neutral light, head light or blinkers and it didn't do anything when I hit the starter button. But the horn worked fine normal loudness. The battery is about 2 years old. Anyone has any suggestions? Thanks so much,Nancy
I just had my 99 sportster bog out on me with everything turning on and off while riding, and now wont do anything except light up my speedometer when it's on acc. Battery is good, new ignition module and been trying to figure out why it's not starting back up, maybe a ground or starter?
Old Jul 8, 2020 | 06:30 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
How did you determine that the battery is good?
Old Jun 15, 2023 | 07:40 PM
JimiIsFrustrated's Avatar
JimiIsFrustrated
Stage II
Default Need help... I have same problem. What was wrong with it?
Originally Posted by fl_flstfi
having similar issue with fatboy. Charged battery but now get no lights (speedometer, etc) when key turned to "ignition". Do get light in speedo when turned to "accessory".
Battery at full charge. All fuses look good. Could this be the start relay? I wouldn't think that would keep lights from coming on.
what was wromg with it.... I have the same problem
Old Jun 15, 2023 | 08:10 PM
NorthWestern's Avatar
NorthWestern
He hasn't logged in here for 12 years. I doubt you will get that answer. Try starting your own thread if you need some help.
Old Feb 19, 2025 | 11:39 AM
Ben_Weez's Avatar
Ben_Weez
Stage IV
Hi, I have same year and same issue did you figure that out?
nodhtims
Jun 15, 2023 07:52 PM
James Zipprian
Oct 9, 2016 05:15 AM
Ralph77
Welcome Area Only
16
May 31, 2012 04:35 PM
4speed351
Jan 29, 2010 08:53 AM
Bollocks
Oct 8, 2006 07:17 PM
