Ordered a FP3
Old Aug 25, 2019 | 11:11 AM
Frez1812's Avatar
Frez1812
Default Ordered a FP3
Just ordered a FP3 for my 2009 heritage Softail. My bike is set up as follows ....
Vance and Hines true duels
K&N air filter
Flashed by Harley
Screaming eagle compensator
Right now I get some popping on decel when temps are up. I was told I will notice a difference in throttle response and it should cool my bike down a bit.
Looking forward to trying it out.
Any opinions or suggestions?
Thank you!
Old Aug 25, 2019 | 05:19 PM
MyFavRk's Avatar
MyFavRk
My best recommendation would be to call V&H as soon as you get it hooked up and it recognizes your bike's serial # . Tell them your exact set up and they will recommend the right map to flash it with . Then change the throttle response to "aggressive " . Try running that for awhile , a tank or so and if your still getting some popping go back into your map settings and use the decel pop setting and start with 1 firecracker and move up from there and see if that helps .
Now , make sure you don't have any exhaust leaks to start or you will always have a popping issue that will be hard to get rid of .
V&H may recommend doing an auto tune , but with just a standard stage 1 , you should be ok with just some minor adjustments to get it tuned just right .
Later on , you could try running the auto tune feature and seeing if there is any improvement . the program will create a new spot just for the autotuned map , so if you want to go back to the original map ( not the stock one ) you can .
Example :
Slot #1 = Stock Map , your original map on the bike right now
Slot #2 = New Flash , the map they recommend , aggressive setting , trying the firecracker setting to get rid of popping .
Slot #3 = Autotune , the map above that will be tuned . If the autotune doesn't work out , you can reflash the bike back to #2 and delete #3 or resume autotune and see if it improves .
If you end up having a hard time dialing it in , you can also upload the map to V&H and they can make changes to your map and send back to you . Call them first and explain to them whats going on , most of the time they can get you going over the phone .
Hope this helps , enjoy and ride safe !
Old Aug 26, 2019 | 07:10 AM
Frez1812's Avatar
Frez1812
Yes, that helps me alot. I appreciate you taking the time to explain all that to me. I didn't realize how much you can actually do with the fuel pack. Can't wait to get it and try it out. I hope I can feel a bit of a difference.
Right now I'm getting great MPG for fuel. It seems to run a tad hot, I guess it's lean. Looking to improve throttle response and cooling it down a bit and maybe less popping on decel.
Thanks!
Old Aug 26, 2019 | 07:46 AM
Stinger1's Avatar
Stinger1
Like you I have an 09' only a Fatboy.
I have a stage 1 but with Rinehart slip ons. There is no map for Rineharts so I used the autotune first. It was good and then I called V&H as suggested above and they suggested a map already in the system. I flased it in and it made a really nice difference. I set the decel pop to 1 firecracker and bike runs awesome!
The autotune takes a while to get all the cells filled. You will never get them all filled so don't worry about that. You will have to do alot of different riding speeds to get the autotune working correctly. As suggested above give V&H a call and they will get you dialed in.
The Fuel Pac is an awesome piece and is really easy to use once you get it figured out. Good luck.
Old Aug 26, 2019 | 10:25 AM
rosefromashes's Avatar
rosefromashes
I wonder how good the current tune is that was flashed by Harley (dealership?). They may have flashed a map that enriches the mixture and advances the timing already.
I'm no expert, but I learned a lot about how my ride behaves by watching the real time data... MAP sensor, TPS sensor, AFR target, Engine Temp, Intake Air Temp. I kind of geeked out and began tweaking the tune - like AFR richer for WOT, but a bit leaner for the RPM and throttle range where I cruise. I also increased the acceleration enrichment a couple points, which gives a brief surge of extra fuel when you roll on throttle. That seemed to have the biggest effect of throwing me back when I roll on throttle
One thing I noticed about the FP3 canned maps was that the AFR and the Spark Advance maps are the same across the board for my model (2015 Softail). The only thing that is different from map to map is the volumetric efficiency tables, which are basically fudge factors that your bike has preset to help her hit her AFR targets. So if you are wide open throttle at 3000 rpm, your AFR map might be commanding 12.8:1 air/fuel but if your VE table isn't tuned right in that square, she might be running way leaner like 13.5:1, but thinking she's right on target (or richer). So Autotune helps that square get much closer to the right value... maybe 12.7 or 12.9
Its important to realize that autotune doesn't do anything to the AFR or the spark advance tables to maximize torque or horsepower... that's what a professional tuner would do (I hope).
If your model has it, you can also turn on EITMS which helps you not roast at long stop lights. If you have automatic compression release, make sure to turn that switch on for easier startup.
Old Sep 10, 2019 | 04:34 PM
Frez1812's Avatar
Frez1812
Finally got my tuner hooked up and the bike flashed. Had an issue with getting the firmware update to finish and install, but it went.
Took the bike for a short ride to the gas station. What I first noticed is how fast the bike runs in each gear. I was in third gear and running 45MPH, it felt like it was in 4th gear already, does that make sense? I mean, it seems to be much more faster in the top end of the RPMs. When it stops raining I'm heading back out.
My only problem is......
Where the hell is there room for it under that seat ? I really want to hook it up and leave it so I can run autotune it. Man, it's super tight under there and I don't see any place for it.
Old Sep 10, 2019 | 07:14 PM
MyFavRk's Avatar
MyFavRk
Not sure on your bike , but my connector is in the left side panel , I just took a wire tie and fastened it to the backing plate . I can take a pic if you like .
Old Aug 4, 2020 | 09:34 AM
JakeC7R's Avatar
JakeC7R
Perhaps another piece of the puzzle, got a trouble code today.
Started it up and I was riding to work. Before hitting the freeway, the temp sensor was at about 180 and just like clockwork, a little backfire and then it dies. On the side of the road it starts back up and I immediately looked for trouble codes and got this one -
B2201 - Ignition Switch off with VSS
The description says check for open circuit or damage in ignition switch signal wire to BCM
So I guess that is something. Of course after I restarted and got it fully warmed up it went the remaining 30 minutes to work with no incidents. I guess it is a clue but not sure how to isolate the problem based on this.
anwas
Jun 19, 2013 02:44 AM
camden
Oct 2, 2012 06:28 PM
kameraman59
Feb 3, 2011 09:16 AM
Gunner11b
May 27, 2010 12:08 PM
chuckb16
Exhaust System Topics
Aug 8, 2009 01:43 AM
