idle speed
Old Dec 31, 2019 | 10:12 PM
Budman88's Avatar
Budman88
1st Gear
Default idle speed
my 2001 electra glide started to idle really high around 18 to 2000 after normal operating temp. i replaced the engine temp. sensor and still have the same problem any ideas or suggestions would be appreciated
Old Dec 31, 2019 | 11:11 PM
Ed Ramberger's Avatar
Ed Ramberger
3 come quickly to mind: Intake leak, sticking ISC motor, possible TP sensor. Does the idle just slowly rise as it warms up?
Old Jan 1, 2020 | 10:26 AM
Budman88's Avatar
Budman88
1st Gear
No pretty much stays at 18 to 2000 as soon as it gets warm, when starting it starts out around 12 which is higher then it was before problem started
Old Jan 1, 2020 | 11:14 AM
Ed Ramberger
So it starts at 1200 and increases to 2000 as it warms up? If so, I would visually verify that the ISC moves in and out at power up/down.
Old Jan 1, 2020 | 06:14 PM
Budman88's Avatar
Budman88
1st Gear
Thanks will do
Old Jan 1, 2020 | 06:37 PM
springers4ever's Avatar
springers4ever
Cool magneti marelli fuel injection...
If you have this type of fuel injection ...(think you do ) ...Check out this video ...
it show the procedure being done on an EVO ...but will work on the twin cam just the same
check for intake leaks at the head first , repair any found then do this ....
we have made this adjustment many times and it works perfect !!!
don't think you have an IAC motor ...
https://www.youtube.com/watch?v=bY6Pw8WpSfc&t=297s
also this thread here ...https://www.hdforums.com/forum/touri...libration.html
peci02@bellsouth.net
Apr 19, 2017 05:28 PM
Silvertrain1025
Mar 2, 2013 09:31 AM
TomWoodgeard
Oct 15, 2011 08:16 PM
gazzer
Jun 30, 2008 05:10 PM
Win_Brad
Mar 15, 2008 10:42 PM
