Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I recently purchased a Dynojet PCV for my 06 FXSTI thinking I can easily replace the Cobra fi2000 that was installed when I bought the bike. The settings got jacked on the Cobra so I set them back to the original configuration and the bike hasn't ran right since. I went through the motions for installing the PCV disconnecting the Cobra, turned on the ignition hit start and nothing. Connected the Cobra back up and it ran, but I think the two have to be conflicting with each other.
I need to know how can I run just the PCV eliminating the Cobra? I have just a stage one kit on the bike eventually stage two that's another reason I bought the Dynojet. Any help out there would be excellent.
Did you load a map onto the PC 5?
Is the latest dynojet software on your computer and does the pc5 have the latest firmware update?
Only 1 tuner is needed, all it will do is conflict as you had experienced.
Exactly..remove the pc5 if its still connected, reflash the ecm back to the original saved map from the cobra, remove the cobra and install the pc5 with the correct map.
