starting
Old Jul 26, 2007 | 08:09 AM
vulhalla's Avatar
vulhalla
Default starting
My 03 Heritage turns over a couple more times before kicking life into her. sometimes it takes 2 times pressing on the starter switch so basicaly its taking longer to start.
Any suggestions?
Or is it really nothing
Old Jul 26, 2007 | 09:47 AM
geargrinder's Avatar
geargrinder
Default RE: starting
Assuming nothing else has been changed, many of my hard starting problems are solved by adjusting the throttle blade adjusting screw for its closed position. Being a mechanical device, they seem to drift to a more closedposition with age and mileage which affects initial starting or it's ability to continuerunning once it starts. You could check this the correct way by going thru all of the serv manual TPS, throttle position, etc adjustments or you could do it my way, give the throttle position screw a quarter of a turnmore open it to see if it helps or hinders and go from there. Just keep track of where it was before you started adjusting in case that was not the problem and now you have two problems.
Old Jul 29, 2007 | 03:42 PM
vulhalla's Avatar
vulhalla
thanks for the advice
Bbryn
Apr 28, 2019 01:41 PM
Stevo1340
EVO
Nov 13, 2018 03:23 PM
Gooberguy
Jul 20, 2011 09:37 AM
Calwoodbutcher
EVO
11
Aug 22, 2007 06:02 PM
pig iron
Exhaust System Topics
Apr 13, 2005 12:09 AM
