.010” oversize piston - do I need to retune other than adding fuel?
Old Sep 2, 2020 | 11:30 AM
Zpr01's Avatar
Zpr01
Default .010” oversize piston - do I need to retune other than adding fuel?
I’m doing a top end rebuild on my 2009 Harley Davidson dyna super glide fxd as you may have seen in another post of mine. My bike is completely stock but I am going to change my exhaust after rebuild is complete. My cylinders are out of round so my machinist recommended me going from a 3.750” bore to a 3.760” bore. I planned on getting a pair of FL-VIED’s to add more fuel to my bike. Do I need to do anything else with the tune to go with the slight oversize? I will be getting stock compression pistons although using a cometic .030” MLS head gasket. Thank you for the help!
Old Sep 2, 2020 | 08:19 PM
Ed Ramberger's Avatar
Ed Ramberger
The exhaust change will have a greater effect on needing fuel mapping than the slight oversize.
Old Sep 4, 2020 | 12:02 PM
60Gunner's Avatar
60Gunner
The slight over bore will have no effect.
Old Sep 4, 2020 | 03:52 PM
Jay Guild's Avatar
Jay Guild
I think you should be good. A bit more compression and better exhaust flow should be handled well by a pair of Fl-VIED. If you do cams you'll want a tuner though.
Old Sep 4, 2020 | 07:56 PM
Ed Ramberger
I wouldn't waste time with VIEDs if you are changing exhaust. Get a PowerVision, and be done with it.
asahi1234
Exhaust System Topics
20
Feb 7, 2014 08:39 AM
Keithhu
26
Nov 13, 2013 06:33 AM
sg34
May 4, 2013 03:21 PM
tlp55
Jun 25, 2012 10:24 AM
wrenchguy24
Mar 8, 2011 10:54 AM
