Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Hi, what is your opninion on oil vapour going into the air filter, creating carbon build up?
I just bought a bike with 3000 miles, and i want to keep combustion as clean as possible....
Should I run it outside the intake? Or dont bother?
I guess, I'm in the 0.001% group that says, if it ain't broke don't fix it. 3 of my bikes vent to atmosphere, 2 to canisters and the atmosphere, and 2 to the AC.
Keeping a little oil out of the intake will help very little, most of the carbon build up comes from the hydro-carbon you fill the gas tank with.
If you get 50 miles per gallon, you are running ~80 quarts of hydro carbon through the gas tank for every 1000 miles you ride.
You would probably have less carbon build up just by running a Top Tier gasoline with additional detergents added.
