full throttle problem
Old Apr 15, 2021 | 11:06 PM
Zanthamos's Avatar
Zanthamos
That is a single fire ignition system and the ignition module is behind the points cover most likely a ultima 944 or a dynatek 2000i. Take off then points cover and watch as it runs look for the flashing LED. You cannot just swap front to rear on a single fire system, only on a dual fire system. Then3 posts on the coil is a dead giveaway for the single fire, dual fire has 2 posts.
Old Apr 18, 2021 | 05:51 PM
Mick85's Avatar
Mick85
1st Gear
when the bike is running the led is flashing and on the coil i also swap the spark plug wire, just heard that the bike has always run like that so he's gone pick it back like that
Old Apr 18, 2021 | 11:08 PM
Zanthamos's Avatar
Zanthamos
Always run like that, that's not good. Sounds like the ignition module is working at idle, may not be at WOT but more likely the carb float in the bowl is set too low. This will give you good idle and lower RPM but steadily poorer performance as you twist the throttle.
Old Apr 19, 2021 | 05:18 PM
60Gunner's Avatar
60Gunner
I wouldn't go any further even trying to guess til that carb is rebuilt., 95% odds that's the problem anyway.
Probably a clogged main.
adamk
Jul 12, 2017 06:47 PM
Windex
Jan 21, 2014 10:09 PM
bmassarani
Ironhead
23
Dec 12, 2011 08:01 PM
GriffTannon
Aug 28, 2010 06:50 PM
matt527
Exhaust System Topics
Oct 20, 2009 08:35 PM
