5 pins in 6 pin can bus
Old Apr 7, 2021 | 12:38 PM
jaybox79's Avatar
jaybox79
1st Gear
Default 5 pins in 6 pin can bus
Just ordered a FP3 for my 2014 RoadKing. I tried to install it, but it’s not reading the bike. After I
looked at the 6 pin connector closely looks like there is only 5 pins. Would there be a reason to remove a pin?
Old Apr 7, 2021 | 12:48 PM
TriGeezer's Avatar
TriGeezer
Are you sure that’s the ECU connector?
Old Apr 7, 2021 | 12:56 PM
jaybox79's Avatar
jaybox79
1st Gear
Fairly certain. I could be wrong though. It was on the left side under the panel. The FP3 fit perfectly in it. Haven't seen any other connector that the FP3 would fit into.
Old Apr 7, 2021 | 02:01 PM
TriGeezer's Avatar
TriGeezer
Sorry, I can help ya. I looked in my ‘17 FSManuel, and there aren’t a lot of 6 pin connectors to get confused with. Is it possible the pin came loose and is dangling?
Old Apr 7, 2021 | 06:50 PM
smitty901's Avatar
smitty901
2014 uses 4 pins not 5 or 6
The connector is a 6 pin type but only has 4 pins. There are two connectors under that side cover one is the Data port the one you want. The other is an accessory port.
Old Apr 7, 2021 | 09:24 PM
Max Headflow's Avatar
Max Headflow
The DLC connector on a 14 RK only uses 5 pins. Pin 4 should be empty.
Old Apr 7, 2021 | 09:39 PM
GearheadMike's Avatar
GearheadMike
You have the right connector. The FP3 only uses 4 of the pins, pwr, gnd, and two canbus.
Your FP3 is new (they marry the vin). So your phone won't connect to it? Ignition on? Got the latest V&H download?
Their support can help you.
610Low
May 19, 2020 01:59 PM
jester0618
2014-2024 Touring Models
Oct 5, 2018 07:54 AM
Marlboroman1717
Electrical/Lighting/Alarm
May 3, 2018 10:13 AM
sajackson
Apr 25, 2009 06:04 PM
Duck
Dec 25, 2007 09:49 PM
