PowerVision Auto-tuning ride hard or easy?
Old Apr 15, 2021 | 09:01 PM
TruckerXbones's Avatar
TruckerXbones
Default PowerVision Auto-tuning ride hard or easy?
Just a basic question. When in AutoTune should I try to ride “hard” as in shift higher in the Rpms or try to shift early and take it easy? I know the videos all say to ride how you normally would. But I’m wondering if there’s an approach to get the “best” tune? I’ve noticed if I take it easy and shift early it doesn’t ask me to Scale or Cap the VE Tables, it’s keeping it under the 127.5. If I wind the gears out in higher Rpms then i hit the 127.5 max in a lot of cells. Which method is getting me a better tune? In my case it’s basic AutoTune with Stock o2 sensors.
Old Apr 15, 2021 | 10:47 PM
Zanthamos's Avatar
Zanthamos
The more data it can collect the better, are you saving and flashing after each ride?
Old Apr 15, 2021 | 10:49 PM
bunk216's Avatar
bunk216
I'd recommend taping or mounting your pv so you can see it while you're running around. It will give you a better idea of what parts of the table you still need to hit. I'd recommend majority of your auto tuning to be as you would normally ride. But making sure to get a few wide open pulls too.
Old Apr 16, 2021 | 05:07 AM
TruckerXbones
Yes I am flashing after each session. But it seems I’m getting different data based on how I ride. I know the goal is to hit as many cells as possible but do you also want to max out each cell as much as possible? Seems if I ride more aggressive I hit the 127.5 ceiling in a lot of cells. Then I’m prompted to Cap or scale. If I ride easy, I still hit as many Cells but I stay below that 127.5 ceiling.
Old Apr 16, 2021 | 08:51 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I did several auto tunes on my Powervision and did not take it easy. The data I recorded did very well all around. Here's a pic of my AFR's.
Old Apr 16, 2021 | 09:00 AM
TruckerXbones
That’s the AFR table. My understanding is the AutoTune feature only makes changes to the VE tables. Which let you know if your hitting the manually set AFR settings in the original map. Or am I wrong? I’ve run a bunch of AutoTune sessions and the VE tables front and rear are the only changes it makes.
Old Apr 16, 2021 | 10:13 AM
98hotrodfatboy
Not sure, I'm fairly new to this myself and in another thread I have going on in the dyno room these were some of the answers I was looking for.. ie: the attached file.. I thought that they were Target AFR's but no on would confirm.. I'll check me ve tables when I get home from work..
Old Apr 16, 2021 | 10:21 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
As the VE table is throttle position vs RPM it is the ability to hold an engine rpm with a throttle position long enough for the software to make the readings it needs.
One method is to find long uphill sections of road that allows you to load up the engine.
I recently saw one person discuss getting into 2nd gear and then slowly opening the throttle and by watching the screen see how each cell gets filled in. Then change into 3rd and the same, then 4th and 5th.
Old Apr 16, 2021 | 06:10 PM
60Gunner's Avatar
60Gunner
Those are target AFRs. You can change them to whatever you want your AFRs to be but what you actually get depends on how accurate your VE tables are.
None of my target AFR cells are leaner than 13.8 and that's in a small area of my cruise and I'm running a lot of 13.2 - 13.5 given my higher rpm cruise around town where airflow is lacking to help with cooling. Higher rpms/load WOT target AFR is as rich as 12.0 and that's what the SE Pro Super Tuner had in those cells in the first place and gave me 13.0 across the board in a wot pull on a dyno.
14.anything is too lean imo.
I hotrod a lot and I'm looking for AFRs where my engine is smoothest and coolest and could care less about mpg. I get 30ish hotrodding around town and 40ish cruising on the highway.
To get as many of the cells as possible in the VE tables, you want to vary the load at different rpms in different gears.
The optimal idle AFR for Harleys before EFI and the EPA was 12.8 btw. Optimal power is 12.8 - 13.2.
Old Apr 16, 2021 | 06:49 PM
Zanthamos's Avatar
Zanthamos
You are correct sir, AT only impacts VE tables and not target AFR, the VE gets adjusted to get the AFR closer to the target AFR and with stock O2 sensors used in the basic AT you are limited to the stock 14.6 AFR readings.
