04 EGC intermittent codes, need help
Old Jun 12, 2021 | 11:53 AM
sjones73's Avatar
sjones73
Default 04 EGC intermittent codes, need help
Ok people, just like the tittle says. I have intermittent codes.
Codes would be P1353 and P1356 codes.
Bike runs great at all speeds/rpm's. I do get a ticking noise at idle after running. Let it cool down and the ticking goes away. Cams have been changed (Andrews 21 chain) cam plate and oil pump update (screaming eagle plate and pump) Lifters and pushrods have been changed also. (S&S pushrods and twin power lifters)
I have followed the diagnostic flow chart from Harley for these codes. All check out good and in spec.
Any other ideas?
Thank you
Old Jun 12, 2021 | 01:11 PM
marcodarq's Avatar
marcodarq
use the stock 6R12 plugs gapped correctly and make sure your plug wires are in good shape, stock replacements are so cheap you might just through some on cause yours are so old, if they are the originals.what did you do to tune the bike for your cams?
m
tracman63
Exhaust System Topics
49
Sep 15, 2019 11:24 AM
RoadGlide_13
Engine Mechanical Topics
Mar 4, 2015 11:11 AM
billytwobags
Oct 3, 2013 04:17 PM
remmag
Jul 16, 2011 04:17 PM
user 8373900
19
Apr 14, 2011 03:56 PM
