Thunder max tips/suggestions
Old Dec 3, 2021 | 08:12 PM
bikridr69's Avatar
bikridr69
Default Thunder max tips/suggestions
Just installed my stage 1 on my 2020 rgs . S&s sidewinder 2-1, s&s high flow air filter, and Thunder max tuner. Any tips/suggestions for settings? Already set the base map. I do have a little bit of fluctuating idle. Only have maybe 10 miles on it since installed. Hopefully putting more on tomorrow.
Old Dec 3, 2021 | 08:50 PM
Tcrafty's Avatar
Tcrafty
Hardest thing to do is simply ride it and let it do its thing initially. It'll tune itself to the settings within the tune. After several hundred-mile runs and writing the changes to the maps, then decide what you would like to change about the tune. Go slow and give Tmax time to adjust to the changes. Many (myself included) want to make changes and "FEEL" the difference. That may come, but first let the map tune to your bike (pipes, injectors, airflow, etc.) No two bikes are the same so the tune needs to adjust to YOUR bike.
My two copper pieces. Others will likely chime in with more useful information. Take time to get to know the system. There's a LOT it can do!
Old Dec 3, 2021 | 09:23 PM
bikridr69's Avatar
bikridr69
thanks a lot. That’s kinda what I thought, but figured I’d ask just in case there was some settings I could do to help get it started.
Old Dec 4, 2021 | 12:05 PM
nevil's Avatar
nevil
You should go for several rides before making any adjustments. Don't know if the advice is still the same as it was a few years ago, but it was recommended to me to ride at least 30 miles at a time, changing up speed, gears, rpms, load, etc. After 300 miles take a look at the map. Basically, just have some fun.
Old Dec 9, 2021 | 05:31 AM
highwayman50's Avatar
highwayman50
According to two of my friends intimately familiar with Thunder Max's anything short of tossing them in a fire while drinking an adult beverage is pointless. Motorcity Harley won't even touch them anymore.
That said, maybe a Dyno tune by someone familiar with the TM is in order.
Old Dec 9, 2021 | 11:09 AM
Jay Guild's Avatar
Jay Guild
I'm happy with the TMax and most tuners won't touch them, mostly because they use different parameters than what most systems use. I can say that most of their maps run very rich so you should see some decent get up and go but that cruising area will need some adjustment if you are worried about milage.
Old Dec 9, 2021 | 11:42 AM
tunaman's Avatar
tunaman
I had a TMax on my FB, and I was very happy with it while I ran it.
I ultimately replaced it with a TTS when I did my 107 upgrade, not due to dissatisfaction but because I wanted to have it dyno’d and the tuner I selected used the TTS exclusively.
Old Jan 27, 2022 | 11:05 AM
Rodman141's Avatar
Rodman141
Have you seen this?
Link
Old Jan 27, 2022 | 11:26 AM
twincam10353's Avatar
twincam10353
You gotta ride it, 10 miles ain't nothin. I'm talking a few hundred miles minimum before you write the first AutoMap. You want to get a lot of varying speeds, rpm's, hill climbs, hill descents, etc. TMax has a published instruction sheet that describes exactly what I'm talking about.
Also - any good tuner will work with and welcome TMax. But in your specific case of just pipes and an intake you really don't need a dyno tune the TMax should be able to do everything you need. You have the most simple / common setup there is (a stock engine with a 2-1 and an intake).
Additionally, I've always experienced great customer service with TMax. Don't hesitate to pick up the phone and call them.
Old Jun 15, 2022 | 11:34 AM
1Performance's Avatar
1Performance
Stage II
Hi Sir I Need the tune for thunder max Bike road glide special 2020. can you please find me any supplier how can i shipped this to qatar ?
