Ignition module
Old Mar 28, 2022 | 04:55 PM
carlmartine's Avatar
carlmartine
Red face Ignition module
I would like to know from those of you who have a Dynatek TC88-2P ignition module what the purpose of the advance feature is for. I know it advances the spark, but exactly what happens when I do that? I currently have my Dynatek module set at 36B. i tried setting it to 34B, but it ran rough. I then set it to 38B, and it would try to buckle when I shut the engine off. But why would a novice like me want to mess with changing the spark? My mechanic tells me that my engine is now a 113 ci. The previous owner installed the Dynatek because the engine is high compression and has compression releases, and other modifications. It is a moderately modified engine I suppose. Sometimes, when I shut off the engine, it does not come to a full stop smoothly. I can only describe the sound as if the crank was trying to go in reverse before it comes to a full stop, and I hear a loud clank (not from the tranny).
Old Mar 28, 2022 | 05:49 PM
strych9's Avatar
strych9
An engine runs at peak performance when the ignition timing advance curve is set to the highest degree possible without detonation. This module gives you the ability to do that.
Dynatek recommends starting at 36A which closely matches a stock ignition advance curve, and add more advance to find the "sweet spot" your engine likes to run at. If it's pinging in the beginning of the process, switch to B curve adjustments, and so on.
In case you don't have them, the instructions are attached. Good luck.
File Type: pdf
Old Mar 28, 2022 | 07:38 PM
carlmartine
Talking
Can a change be done while the engine is running? If not, I suppose you make the change, take it out for a spin, and depending on how it runs, you change it while the engine is off? The previous owner had a dyno test done in 2018. The dyno sheet says that changes were made to the CV carb during three runs, but it does not say anything about the ignition module, or if it was installed at that time. I tend to believe that it was specifically set at 36B during the dyno runs, so that is why I hesitated to change anything, since it has been running pretty good. Besides, I am dangerous man in that I don't know what I don't know!!
Old Mar 29, 2022 | 11:41 AM
Max Headflow's Avatar
Max Headflow
Engine run-on is typically of a motor that isn't tuned well and too hot of plugs.
Dump your ignition and buy a DTT. Go to Champion RA-6HC plugs. Below is the reason why the Dynatec ignition sucks. Timing curves are all screwed up.
https://www.hdforums.com/forum/engin...l#post20508299
Old Mar 30, 2022 | 09:56 AM
carlmartine
Red face
Thanks. I was already thinking of changing the plugs to 6R12, but I will try the Champion RA-6HC. Also, I had tried one step colder on the RGK plugs, but I can't remember if it was doing the same thing, so I went back to the regular NGK. Maybe I will try another RA-6HC, and if necessary, one step colder. Thx.
Old Mar 30, 2022 | 10:04 AM
Max Headflow
Originally Posted by carlmartine
Thanks. I was already thinking of changing the plugs to 6R12, but I will try the Chamption RA-6HC. Also, what does DTT stand for? Thx.
Don't remember what the stock plugs are but they are likely too hot on a higher compression machine.
DTT
http://www.daytona-twintec.com/tc88twincamignition.aspx
Old Mar 30, 2022 | 10:09 AM
carlmartine
Red face
DTT
Good info. Once again, thanks for your super prompt response.
Old Apr 1, 2022 | 08:10 PM
carlmartine
I have the Champion spark plugs on order. I also downloaded the instructions for the DTT ignition module. It states it requires a coil with less than 0.5 Ohm in the primary. My current coil has around 3 ohms in the primary. I always thought that less than 3 Ohms indicated a bad coil. Will I need to get another coil for the DTT ignition module? And how will the DTT be different/compare with my current Dynatek TC88-2P ignition module?
Old Apr 3, 2022 | 07:49 PM
Max Headflow
This is a twincam? They ere always 1/2 ohm, even stock.. Did someone use and aftermarket coil?
Old Apr 3, 2022 | 09:51 PM
carlmartine
Yes, it is a twin cam. It has an OEM Harley-Davidson coil. I confirmed it with its part no and on Ronnie's Parts List. The Harley service manual for my 2000 Softail states that the "normal resistance range is 5.5-7 Ohms" (page 8-70) for the secondary coil winding. The secondary windings are the towers where the spark plug wires are connected, not the primary posts, whose normal resistance range is from 0.5 to 0.7 Ohms.
