TTS speed limiter issues
Old Jun 20, 2022 | 12:11 PM
Junker's Avatar
Junker
OK. Connect an inline fuel pressure gauge and run her up..
the injector seem to keeping up pretty good, not giving any indication of running out of fuel but I was always curious about the pressure on these things. Do you recommend any gauge kits?
Old Jun 20, 2022 | 12:57 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Originally Posted by Junker
definitely not out of power! You told me there are limiters in the back ground we don't have access to, but I guess only the big name racers get the fixes, seeing you have ghosted me since telling that.
Yes, there are lots of things in the ECM that the tuner does not address, but if the injectors are firing properly (pulse width) and the timing (deg) is still OK, then there is nothing in the ECM limiting! I tried to explain this to you before as that is what is used to limit the power. So if they are fine your looking in the wrong place for answers.
Old Jun 20, 2022 | 01:26 PM
hrdtail78's Avatar
hrdtail78
It is not a dyno problem, it is an ecm problem. On the dyno it goes 165mph@7000rpm. on the road it goes 131mph@5100 rpm. Wind and road resistance isnt going to slow it down that much.
Maybe, maybe not. There are some factors involved, and this includes DJ's numbers.. Rev limit is what is set in the ECM. TTS is pretty straight forward with this setting. The other limiter is speed. You can either lie to your ECM with speedo calibration or unplug the speed sensor for testing purposes. If the ECM doesn't know speed. It can't limit it. Once you have figured out it isn't the ECM limiting you. Then I would look into the advice given above.
BTW TTS doesn't have big racer fixes, then pro fixes and then street guy fixes. They are all the same starting cals, with all the same tools and features. Do you really think TTS would give big race fixes to the Scream'n Eagle race teams that use TTS at the track?
Old Jun 20, 2022 | 02:08 PM
Max Headflow's Avatar
Max Headflow
The only one I've ever used is this one..
https://www.zippersperformance.com/772-457/
There are plenty others out there. You want on that will connect inline so you can test. Pick one you like..
If doing non dyno run, I'm not sure that the injector timing would not be any different than say on the dyno where the run is really short. So not sure you'd see anything. I would assume no fuel trims at those throttle settings.
Sampled run injector timing at speed would be close to the dyno run.. I might guess that you could possibly have detonation that would pull back timing but that should show up on the run..
What is MAP at that speed? Maybe something with turbulence around the air cleaner?
Old Jun 20, 2022 | 04:22 PM
Junker's Avatar
Junker
And if you would have looked at the logs that I sent you, you would have seen that it is pulling way more timing than any map in the tune is showing. And I asked why is it pulling so much? But again you gave no responses to my e mails. I thought asking you directly and giving you all the information that I had was looking in the right place for answers.
Old Jun 20, 2022 | 04:40 PM
Junker's Avatar
Junker
the last time on the dyno it was hitting some limiter, we tried unplugging the sensor n the dyno and made no change. However after plugging it back in it did run up to 7000rpm@160+ for the rest of the runs. When I got it on the road it was started running 5600rpm@131in 5th and 5100rpm@131. Tried unplugging the speed sensor but it never changed anything. The only physical difference from the dyno to road is the front tire turns on the road. There is more stuff going on in the back ground than we/the end user can control(or have access to).
Old Jun 20, 2022 | 04:42 PM
Junker's Avatar
Junker
I am not trying fight with anyone or bash anyone's company or product. I am just trying to find the answer to my issue.
Old Jun 20, 2022 | 05:00 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Since you now feel the timing is being pulled then one needs to figure out why or is it that the number isn't what you expect it to be. The timing on the dyno under the conditions that made it work would have to be compared against the street numbers to make any sense of it, and what you supplied was only street data and it looked fine to me, as did the injectors pulse width. That fact that it changed on the dyno when the ECM and tuning was never touched, should be a pretty good clue and it pretty much rules out the ECM and front wheel as that never changed either. So why did it change?
Old Jun 20, 2022 | 05:03 PM
Max Headflow
There are big physical differences.
1. The time to get to 131 mph on a dyno is a lot faster than on the road. This extra time means more load on the motor. more heat generated.
2. You'll be using more fuel to do so.
3. Beside the usual drag there is more wind turbulence. There can be some unknown issue that crops up as a result..
I have to admit that it's interesting that in both 5th and 6th the bike stopped at 131 mph. It might be a wind turbulence thing. I mention the AC but it could easily something else.
Old Jun 20, 2022 | 05:39 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
I just got off the phone with the tuner who tuned the bike and first presented the issue to me. He recalled the same thing I did and that was when the data was compared of the good runs on the dyno, and the ones that fell off, the timing, TPS and the fuel (BPW) remained the same! So while there is something going on with this bike there is more that's not known then it being a TTS Speed Limiter issue.
