Ignition UpGrade Question?
Old Aug 14, 2007 | 11:33 PM
07_103_NT's Avatar
07_103_NT
Default Ignition UpGrade Question?
I was looking thru my Parts upgrade book went thru the Screaming Eagle section Ignitions .Found a few upgrades for carberated model bikes .But none for EFI like my 07 NT just cerious as to what upgrade would be available for my 07 103 Nightrain .Is it wise and or worth it to upgrade in that area .
Old Aug 15, 2007 | 06:07 AM
Doc 1's Avatar
Doc 1
Default RE: Ignition UpGrade Question?
The ignition is controlled by the ECU so a SERT or PC would have to be used to alter the timing map.
Old Aug 15, 2007 | 08:03 AM
geargrinder's Avatar
geargrinder
When you state upgrade, do you mean a hardware upgrade like coil, plug wires, ignition boxetc? If so, consider this.Our 107 inch,150+ HP, 6600 RPM, 10 PSI of boosttwin camhas been runningperfect for several years, knock on wood,witha 100% stock ignition system, copper core plugs. Today's stock electronic ignition systems have more spark energyavailable then most will ever need, plus more reliability then any performance upgraded system. Don't let a bunch of marketing hypeconvince youotherwise, unless they want to pay to sponsoryou for it. If you are having ignition problems it's either a faulty component or bad tune, don't compound your problems by replacing parts that are not broke.
Old Aug 15, 2007 | 10:01 PM
07_103_NT's Avatar
07_103_NT
ORIGINAL: geargrinder
I was talking about coil, plugs, wires ,and such. Thanks for the the good imput wont touch a thing as far as ignition goes .
Cheers
Old Aug 15, 2007 | 10:03 PM
07_103_NT's Avatar
07_103_NT
ORIGINAL: 07_103_NT
Cheers
road king ed
EVO
Sep 14, 2016 05:44 PM
Mrukus
EVO
Jul 2, 2013 09:50 PM
softail99custom
EVO
Nov 7, 2010 06:44 PM
harleymark
Mar 4, 2009 08:32 PM
92classic
EVO
Mar 29, 2008 08:54 PM
