PC III mounting question
Old Aug 21, 2007 | 01:53 AM
T_Rob666's Avatar
T_Rob666
Default RE: PC III mounting question
I was just told that they don't have them for the 07's and 08's yet...just pre-2006.
Old Aug 28, 2007 | 10:44 AM
Aerosport's Avatar
Aerosport
The PCIII's for the 07 & 08 Softails do not come with the deeper ECU tray. Due to changes in the frame, tire & fender, seat design, it is no longer possible to mount them under the seat in the deeper tray. The tire will hit the tray under certain conditions. The new mounting locatiion is under the mudflap in the rear and it is recommended to hook up the usb cable and leave it connected to the power commander and tie up the wires. This makes it much easier to do any changes if necessary.
Old Aug 28, 2007 | 10:48 AM
T_Rob666's Avatar
T_Rob666
ORIGINAL: Aerosport
Well, I'm here to tell you that it IS possible...I made a deeper tray for my 07 and it works just fine. Hell...my bike is also lowered 2"! They just haven't designed on yet...if they do. But, it is possible. Mine doesn't rub the tire at all.
Tim
Old Aug 28, 2007 | 12:50 PM
turbo54's Avatar
turbo54
I Don,t about the soft tails .I installed my pc 3 on the left side above the fuse box that was on a 2000 RG.
WARG
Dec 1, 2009 10:13 PM
Mrawsome21
Sep 13, 2009 12:11 PM
jackinthebox
Mar 1, 2009 06:27 PM
VigilantOutlaw
Jun 23, 2008 08:53 PM
05 HD Deluxe
Apr 5, 2008 06:10 PM
