Screaming Eagle Ignition Programmer???
Old Aug 25, 2007 | 09:32 PM
R1Geezrglide's Avatar
R1Geezrglide
Default RE: Screaming Eagle Ignition Programmer???
Well, I've gone through the carb. Both the oil breather pipes off the heads were split,the vacuum port for the charcoal cannister (yep, it's a Kalifornia model) was left open after the lines were removed. The cannister is still there, however. The idle mixture plug was still in place. So, after a trip to the dealer and the hardware store, I have spent a total of $13.56 (eat your heart out FI guys) and have a 190 and a 195 main that turns out doesn't fit my emulsion tube-go figure. I've plugged the vacuum port for the charcoal cannister. The port vents into the throat in front of the throttle plate, behind the slide. Drilled the mixture plug and left the jets alone. I also replaced the oil breather tubes. Bottom line, the bike runs significantly better. I still get some ping, but only after the oil temp gets over 200. Although I didn't get to go on a long ride, the engine oil temp seems to be about 15deg cooler. I'll play with the jets some more once I get some that fit.....
Old Aug 25, 2007 | 10:11 PM
eraser50's Avatar
eraser50
4th Gear
well go figure all them there leaks would create all them problems i would check the accelerator pump and the needle valve for correct fit when your done check your spark plugs, well i am in california, raised in corpus cristi go figure but i removed all that california emissions crap great for cars not for bikes got a nightrain 05and a dyna 03 the dyna is the ol ladys sled
Old Aug 26, 2007 | 10:59 AM
R1Geezrglide
Yes, it 's a wonder it was even running. I was surprised to find the cannister still mounted with some of the plumbing intact. I'm afraid my my friend had some of Temecula'sfinest hacks working on this bike. His intent was good and he paid a lot of money for the work that was done, but the things I have run across as I have been going through this bike is nothing short of pure incompetence. As with all things, his loss is my gain and I will eventually get it all sorted to be the bike it was intended to be.
Old Aug 26, 2007 | 11:04 AM
eraser50's Avatar
eraser50
4th Gear
some people claim to know what they are doing but dont know diddley i find the best way is buy a shop manuel and if your not sure what to do talk to the dealer then get a second opinion its like going to the doctors
Old Aug 26, 2007 | 11:29 AM
R1Geezrglide
I spent years as a Mercedes Tech before I went into management. I guess my expectations are too high as I find ignorance is rampant at all levels, dealer and indy combined. I'm trying to be kind as I know a lot of it is lack of training. However, some is a combination of arrogance/stupidity. It's kind of like the guys who stillswear points are better than electronic ignition.
Old Aug 26, 2007 | 11:55 AM
eraser50's Avatar
eraser50
4th Gear
no i dont think your expectations are too high you like everbody else wants the job done correctly and quickly with the upmost professinalsm its what we all want we dont care for B.S.
Strannix
Jun 28, 2017 01:24 AM
magnum629c
Jan 22, 2013 06:02 PM
BB4xl
EVO
21
Jun 3, 2009 10:27 AM
swampking
Mar 22, 2008 07:31 AM
Jimbo1221
Jul 1, 2006 04:36 AM
