Screaming Eagle Ignition Module review.
Old Jun 25, 2006 | 06:10 PM
Jimbo1221's Avatar
Jimbo1221
Default Screaming Eagle Ignition Module review.
I have the whole stage 1 kit - SE high flow a/c, carb rejet, and SEII slip ons. And recently added forward controls w/ 2" extensions to my 2006 sportster 1200 Low. I just bought the Vance and Hines Short Shots Staggard and the Screamin' Eagle Ignition Module. Had both installed, and with that Ignition Module it makes A HELL OF A DIFFERENCE!!!!! If anybody thinks the 1200's are good on power but don't have quite enough, get the module! Best purchase so far! I will be getting it dyno'd in a few weeks, just to see what my numbers are at.
Old Jun 25, 2006 | 06:30 PM
jshall755's Avatar
jshall755
Default RE: Screaming Eagle Ignition Module review.
I'm still learning so take it easy on me, but our bikes have ignition modules and not distributors? I always figured that having a carb meant having a distributor and having fuel injection meant having an ingition module.
Old Jun 26, 2006 | 02:07 AM
Jimbo1221's Avatar
Jimbo1221
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Controls spark/ignition - allows to rev to 7,000 RPM. At wide open throttle, it retards timing by 5* allowing it to rev up higher.
Old Jun 26, 2006 | 04:05 AM
boom215's Avatar
boom215
only thing i dont like is if you get it for your 883 you need to get a diff one for your 1200. Or they sell two diff. ones at least.
Old Jun 26, 2006 | 10:14 AM
WarriorHD's Avatar
WarriorHD
Wouldn't you have to change your plugs to the platnium tip ones with this mod to get the most out of it? I would also imagine pulling the extra 1000 RPM's on the engine will be harder on it. I'm sure life expectancy would drop dramtically if that was constantly done. As a matter of fact, I would guess pulling 6000 all the time would drop life expectancy as well.
Old Jun 26, 2006 | 06:00 PM
tim@tmgdesigns's Avatar
tim@tmgdesigns
6000 RPM isnt alot. The Jap v-twin bikes run at a much higher rpm without any trouble. The problem is somewhere beyond 6000rpm, you run the risk of "floating a valve". This is when a valve actualy hits the top of the piston because the piston is moving faster than the valve spring can react, pulling the valve out of the way. The answer is a stronger valve spring so they move quicker. I dont know at what rpm this can happen, but if the ignition module or the mechanic didnt mention different springs then I am sure you are fine. 7000 isnt alot.
Old Jun 27, 2006 | 11:29 AM
Jimbo1221's Avatar
Jimbo1221
Yeah, I have ordered the Screamin' Eagle Platinum tipped plugs along with new wires. But 7,000 isn't too bad at all.
Old Jun 27, 2006 | 10:04 PM
NoBoZoS's Avatar
NoBoZoS
You're wasting your $$$ on those SE Plugs.....The HD Gold ones are much better after the mods.
Old Jul 1, 2006 | 03:58 AM
hdsporty05's Avatar
hdsporty05
I also just installed the SEIM and noticed a slight diff...what really complemented it was the new Kuryakyn PRO R Hypercharger that I just installed...
Old Jul 1, 2006 | 04:36 AM
skullcrusher's Avatar
skullcrusher
Its completly plug and play right? No re jetting, just plug it in and you'll notice a difference?
seven7
Oct 3, 2023 04:48 PM
magnum629c
Jan 22, 2013 06:02 PM
BB4xl
EVO
21
Jun 3, 2009 10:27 AM
00ICUR12
Jan 5, 2009 09:01 AM
virtualmike13
Oct 3, 2007 04:13 PM
