Auto tune issue
Old May 16, 2023 | 10:16 PM
sleighcrane's Avatar
sleighcrane
Default Auto tune issue
I have done several auto tune runs but my bike sometimes stumbles when I leave from a stop. Is this something I should be able to correct through autotune or a dyno run? Recently installed S&S 475 cam, jackpot mufflers, on a 2019 road king 107. Bike runs strong just a very occasional cough starting off. Thanks
Old May 17, 2023 | 08:52 AM
strych9's Avatar
strych9
I don't believe auto tune would help you in that range. Sounds like you need to do some data logging to see what's causing the issue. Foremost, check the basics first. I would check my ignition wires first to make sure no spark leakage exists either along the length of the wires or at the plugs. Torn boot? Vacuum leak somewhere? Smacks of a possible misfire. If your fuel tables have smooth transitions in the areas where you have the stumble, I'd be surprised if it were a fuel issue. Good luck.
Old Jul 13, 2023 | 10:42 AM
sleighcrane
After several auto tune runs and another map from FM who have been very helpful I began to see a pattern develop. Bike had to be at operating temp a bit of high speed and then idling. When I would go to leave a stop was when I had the sputter. Realized that my EITMS was enabled and I believe the transition to throttle up was causing it. I have since disabled it and preliminary runs show improvement. Preference would be to get it on a dyno eventually after I find one reasonably close to home.
Old Jul 23, 2023 | 03:55 AM
DeeRoe's Avatar
DeeRoe
So, I've found that with EITMS, if I notice it's activated at a stop light, I'll just blip the throttle before engaging the clutch and accelerating. This eliminated the "stumble" for me at stop lights. Technique, only.
Old Jul 23, 2023 | 10:01 AM
sleighcrane
That's encouraging thought I was actually doing the throttle blip as well trying to overcome it. Simply turning off the EITMS seems to be the trick. With the 475 cam and the lumpy idle lope I don't think I picked up that it was active.Seems fine now
Old Jul 27, 2023 | 01:57 PM
GPHDXLC's Avatar
GPHDXLC
I didn't catch, what kind of tuner do you have??
Old Jul 27, 2023 | 02:57 PM
downzero's Avatar
downzero
That sounds like it's lean to me. If you blip the throttle you're going to get a little bit of "pump shot" fuel to prevent it from going lean when you first crack the throttle. I'm willing to bet if you enrichen it a smidge right where the stumble is, it'll go away without your "technique."
Auto tune is hard in this area because many of these softwares aren't going to want to "learn" when another fuel map is adding fuel, in your case the pump shot or acceleration enrichment.
Old Jul 27, 2023 | 09:09 PM
sleighcrane
I have a power vision 1 tuner. Much better now with EITMS off and no more CEL on showing rear cyl rich. Thanks for all the replies
supernac
May 24, 2023 10:20 AM
SoCaRider
Milwaukee Eight (M8)
36
Sep 25, 2020 09:13 AM
TexasD
17
Feb 22, 2018 12:53 PM
87gtNOS
The Dyno Room
18
Jun 6, 2016 10:48 AM
bobby5
Fuel Moto / Jackpot Mufflers
Jun 3, 2010 08:00 PM
