System will not engage fuel pump to start and run
Old Jan 27, 2024 | 10:24 AM
Ironsickle's Avatar
Ironsickle
3rd Gear
Default System will not engage fuel pump to start and run
I've got a 2009 Sportster and it has ECM on back fender. the system relay will not make contact from the 87 and 30 on fuel pump and ignition. I've cut open a relay connection and put a rubber band around it to keep contact points touching and you have to remove the 30 amp main fuse to turn off fuel pump with ignition switch on. Now. I've tested fuel pump motor and continuity from fuel pump to harness and through switch . Switch tested fine with light bulb test on and off, triple checked my ECM wire to number and their correct from what I wrote down and what Harley gave me out of their book. The relays and fuses test fine but 85 and 86 to on/off switch and ECM. They are not getting power to make magnetic charge to connect the 30 and 87 (ignition to battery and fuel pump).
I need to find out what causes the fuel pump to quit after it runs for 2 seconds when waiting to crank up engine when it's working normal?
If I manually hold the relay shut it runs but fuel pump continually runs
Is the 30 amp green fuse inside battery cover stock OEM Harley or after market like dyna jet I don't remember from my last stock Sportster. I'm trying to figure if a stock wiring harness will fix the issue or how could it be a problem with ECM not telling the fuel pump to come on?
Old Jan 27, 2024 | 10:56 AM
Ironsickle's Avatar
Ironsickle
3rd Gear
Also when the 30 amp main fuse is in the power will drain out wasting my battery. I dont know what would cause the power drain.
Old Jan 27, 2024 | 02:03 PM
paulmedford's Avatar
paulmedford
the ecm grounds the relay primary coil. So check for voltage to terminal 86 on connector side of the system relay (black and white wire) , this is the switched voltage. Then check for continuity from 85 terminal on connector to the ecm ( orange and green wire).
Old Jan 27, 2024 | 05:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Are you working with a factory wiring diagram?
Old Jan 29, 2024 | 07:07 AM
Ironsickle's Avatar
Ironsickle
3rd Gear
I've got a phone picture of their book. I can see everything the relay hooks to. I'm going to try and test where the power stops going to the relay today
Old Jan 29, 2024 | 09:38 AM
Ironsickle's Avatar
Ironsickle
3rd Gear
Just now I have tested continuity with the battery hooked up to see if it has voltage to light a bulb on the white wire w/black stripe from relay plug to the handle bar plug tank. Already tested right hand control switch continuity. The grey has continuity so does white w/ black stripe from relay to switch. Both switches work start and on. The green orange wire at system relay plug to ECM has continuity. The blue grey from plug to ECM has continuity the fuel pump works. I've tried new relays in both positions and it will only turn fuel pump on with the relay shut with a rubber band.
another thing the power drain comes from turning ignition off and it makes a noise at the throttle position sensor. I can unplug the sensor at top of intake and the noise stops.
I don't Have a voltage meter so I tested with a turn signal that I had laying around. If they have continuity they have power right. i don't understand what gives power to the fuel pump when needed and cuts off when needed. Because it won't always have power to the fuel pump when the relay disconnects the contact points.
Old Jan 29, 2024 | 10:58 AM
paulmedford
the ecm grounds the relay through the orange and green wire . If there is continuity from the connector to the ecm and you have voltage on the white black wire then the ecm is not working or you not getting crank signal. The ecm primes the fuel pump for a few seconds when you turn on the ignition then shut it off until the bike sees rotation then it would engage the sustem
relay again. CHeck your bank angle sensor make sure it is working
Old Jan 29, 2024 | 03:33 PM
Ironsickle's Avatar
Ironsickle
3rd Gear
With ignition on and switch off I get;
.65-.7 on 85 and 86
30 has 12.78 volts
87 has .01 volts
Does that mean the plastic relay conducts electricity between the connectors not bringing them to 0
Then when you hit the fuel pump switch on, it'll go to 12.09-12.11 volts on 85 and 86
30 has 12.69 volts
87 has .01 volts
85 and 86 go to the copper wire bundle and charge 30 to make a magnet. 87 isn't connected until 30 shuts to make with it. There's no magnetic charge on 30 when it's not plugged in but I can see it shut and function when there is a battery causing it to shut through 85 and 86.
It sounds like the relay is the problem like it isn't magneting shut. But it works for the starter. If there's power on 85 and 86 shouldn't that charge 30 with enough magnet to close to 87. I've tried 2 new relays
Old Jan 29, 2024 | 04:08 PM
paulmedford
.65-.7 on 85 and 86
30 has 12.78 volts
87 has .01 volts
30 has 12.69 volts
87 has .01 volts
if the relay is plugged in and those are the voltages, then on the 85 pin WITH THE RELAY PLUGGED IN, when the run switch is on it should go from 12.69V to 0V for a few seconds because the ECM is GROUNDING pin 85. If that is not happening then the ecm is not working right . So check the bank angle sensor
Old Jan 29, 2024 | 04:25 PM
paulmedford
With the negative lead on ground and the positive on pin 85 of bike with the relay unplugged and the voltmeter on ohms….you should see a dip in the resistance for a brief period like in the video . This is how the ecm supposed to work so if you have good voltages then you have to check ecm. MAKE SURE ITS ON PIN 85 or you can damage your voltmeter
File Type: mov
